Help me diagnose a ...
[Closed] Help me diagnose a mysterious ticking noise
13 Users
Annoying ticking whilst pedaling my road bike, roughly once every pedal revolution. I thought it was the BB, put a new one in, didn't fix it. Also put a new chain on, tried completely different crank set and pedals, different rear wheel and cassette, nothing stopped it. It happens in all gears, seated or standing. Really vexed! Any suggestions please?
Posted : 19/09/2020 4:48 pm
Headset?
Posted : 19/09/2020 4:54 pm
Is it your hip? 🙂
As above, headset is your next port of call.
Posted : 19/09/2020 5:26 pm
The end of the front mech cable being caught once by the crank arm once every pedal revolution?
Posted : 19/09/2020 5:28 pm
Shoes or cleats?
I had something similar where a bike fitter added plastic wedges to the forefoot of my shoes. They didn't fit properly and flexed under load creating a clicking sound every pedal revolution.
Does it still do it if you put the bike in a stand and you turn the cranks by hand?
That would rule out headset for example.
Posted : 19/09/2020 5:53 pm
 kilo
Pedals, especially if shimano spd-sl
Posted : 19/09/2020 6:21 pm
I had that with a 'carbon fibre' headset spacer! Pressure on one side pedal stroke = click.
Posted : 19/09/2020 7:53 pm
 mos
Same thing happened to me with my cx bike on the indoor trainer. Swapped bb and God knows what else.
It was the seatpost
Posted : 19/09/2020 8:42 pm
Give qr levers a clean down (if not thru axles). That was my last mystery creak.
Posted : 19/09/2020 9:22 pm
Fancy low spoke count wheels?
Clean your bike a lot?
Its the spokes ticking in the rim. Try a tiny drop of oil on each spoke nipple.
Posted : 19/09/2020 9:29 pm
Last mystery creak was a snapped stem for me. I thought there was supposed to be a gap I the middle. Over tightening error😐🙄
Posted : 20/09/2020 2:25 pm
Powerlink (if fitted) on upside down?
Posted : 20/09/2020 3:56 pm
Thanks for the suggestions, after more investigation it turns out I have a crack in the chainstay by the BB 😔
Posted : 20/09/2020 4:55 pm
Ohhh, that's unlucky!
Better to find it now that at high speed somewhere
Posted : 20/09/2020 5:15 pm
Posted : 20/09/2020 6:44 pm
