Help identify this ...
[Closed] Help identify this headset
6 Users
I need some new bearings for my headset.
But I can't work out exactly which FSA headset this is and so I'm struggling to work out which bearings I need to buy to replace the current ones.
I can't find any numbers on the bearings and it just says FSA ACB on the cups.
Any help would be appreciated!
[url= https://farm8.staticflickr.com/7406/12672235693_bb5f0ab51a.jp g" target="_blank">https://farm8.staticflickr.com/7406/12672235693_bb5f0ab51a.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/92338746@N03/12672235693/ ]IMG_1693[/url]
[url= https://farm6.staticflickr.com/5503/12672114415_e230a06948.jp g" target="_blank">https://farm6.staticflickr.com/5503/12672114415_e230a06948.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/92338746@N03/12672114415/ ]IMG_1692[/url]
[url= https://farm8.staticflickr.com/7411/12672594024_51b61059e9.jp g" target="_blank">https://farm8.staticflickr.com/7411/12672594024_51b61059e9.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/92338746@N03/12672594024/ ]IMG_1690[/url]
[url= https://farm4.staticflickr.com/3795/12672116755_192718edf6.jp g" target="_blank">https://farm4.staticflickr.com/3795/12672116755_192718edf6.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/92338746@N03/12672116755/ ]IMG_1691[/url]
Posted : 21/02/2014 9:28 am
 Yak
Can you measure them -put the dims in here:
http://www.bearing-king.co.uk/how-to-measure-a-bearing.php
and then you'll have a bearing code.
Posted : 21/02/2014 9:46 am
ACB = Angular contact bearings.
Tried here? - http://www.fullspeedahead.com/category_list/53/HEADSETS
Posted : 21/02/2014 9:47 am
I couldn't find any like this on the FSA website, with an integrated top and external lower.
I'll drop the forks out this evening to measure the bearings.
Posted : 21/02/2014 9:57 am
You need to measure the bearings it also depends on angle as well, common ones are;
1" 1/8
36deg x 36deg OD 41.5mm TH-872
36deg x 36deg OD 44mm TH-871
36deg x 45deg OD 41mm TH-873
36deg x 45deg OD 38mm TH-373
45deg x 45deg OD 41.8 TH-870
1" 1/2
36deg x 45deg OD 51.8 TH-073
45deg x 45deg OD 46.8 TH-970
45deg x 45deg OD 52 TH-070
Easy is't it? .2 of a mm difference FFS! 😈
Posted : 21/02/2014 10:38 am
When I had the same problem I carried them into my LBS who pulled out a bunch of bearings they had and let me have one from a tub of spares (new, still in the bag) for a couple of quid. I could then read the numbers for future reference... I didn't, but I could have 🙂
Might be worth a go if you are still stuck?
Posted : 21/02/2014 10:44 am
I did actually try my local Evens yesterday, its my closest bike shop. I went to get some suspension grease so I thought I'd ask whilst I was there. They couldn't help me with either 🙁
Posted : 21/02/2014 11:01 am
[url= http://thebearinghub.com/headset-bearing-models ]Full break down of bearings[/url] to compare against... which may or maynot be of help... Replacement headset bearings do seem to be a nitemare
Posted : 21/02/2014 1:25 pm
