I got this with a new Canyon Strive CF 8. The manual with it had no hint what it was for and basically said get an expert to install. The number on the manual isn't in google and didn't help. The red part is about 15mm wide, the black bit is firm rubber, here is a photo -
Any ideas ?
Got a Stealth Reverb with it? The red bit is for threading hose through the frame...
The red bit is to help threading a Reverb Stealth hose through the frame.
The red thing is a barb for a reverb stealth.
The rubber bit kind of looks like a Pike bladder, but it should be matte with sharp edges.
The black part is for preventing hose kinks (if needed).
Red part is Humidensfier bracket and Black tube is Double Locking Sprocket guide
The bike came with a Reverb Stealth installed so I guess I don't need it unless I remove/refit it. Thanks for the help.
