so, i have a garmin 810, and need to follow the route on this page tomorow night.
https://yorkshiretruegrit.co.uk/gpx-files/
I dont know how to get it on my garmin though. it comes as a zip file.
Any help will be massively appreciated!
thanks
Can you download the file to PC / Laptop?
If so you need to connect your Garin to your PC / Laptop and copy the GPX to the NEW FILES folder.
If you can't get the file downloaded post where you are trying to get it from.
Si
EDIT ** You will eed to extraft the GPX from the zip file and save it on your PC / Laptop.
Download the zip, unzip, put the gpx in the New Files directory on the 810. Just connect 810 to PC using USB cable and open it as an external drive (like a memory stick). Eject garmin from PC.
It then processes the GPX and turns it into a course.
This gives some good info on settings on the 810 as well. https://ridewithgps.com/help/edge-810
thanks! im just trying to unzip it now
Its worked! i was struggling to unzip the file, but its all sorted now, thanks, and ill check the link above
Good news. Enjoy the ride!
