Help - gear cable r...
[Closed] Help - gear cable removal
4 Users
Hi I cannot push the front mech cable out of the Shimano Deore shifter. I have removed the cover screw but the cable won't push out. Rear mech cable came out fine. The Deores are 2014 vintage if that makes any difference. I am not ready for 1 x just yet. Thanks.
Posted : 15/07/2017 5:27 pm
Shifted to the lowest/first position on the shifter?
Posted : 15/07/2017 5:51 pm
If you have a double chain set and the shifter has the little switch to change it between double and triple ?
Then that toggle needs to be set to triple to let you remove the cable
Posted : 15/07/2017 6:07 pm
Orangeboy you are genius.thank you so much Sir. I may ride tomorrow after all.
Posted : 15/07/2017 6:41 pm
Enjoy the sunshine. It's one of those many fun little things Shimano don't seem to anonce
Posted : 15/07/2017 7:06 pm
Yeah I discovered this the other week as well. Sneaky devil's.
Posted : 15/07/2017 7:53 pm
