specifically iPhone4 - any reasons why not?
it costs a fortune?
I might have some scraps that are big enough - so free.
Isn't that all most screen protectors are anyway?
Its what I'm using on a non touch screen Nokia and it appears to work fine.
Isn't it really sticky so if u need to replace it, it might be a pain.
It also might stop a touch screen working? Or perhaps just make it a bit less sensitive.
I use it on my mobile and it's works fine although I'm not sure that the optical clarity is as good as proper screen protector.
I'm guessing it's a bit too thick to work on a touchscreen screen...also for proper stickiness you need to hairdryer it on - which suggests to me it's likely to be 'welded' on and a right PITA to remove if ever needed...
