Getting a new bike delivered today!!
I have some heli tape from Biketart. Does anyone have any really good tips/instructions/tutorials?
I was thinking of using the wet method, does it work well!?
Hair dryer, heat the frame and the tape before applying
Always put mine on dry. Clean surface with IPA then heat frame and tape with the wife's hair dryer. Use curved corners when you cut it, not square ones.
What onzadog said.
I did my top tube neatly, kinda bodged the downtube, then got annoyed and just did the chain/seastays with 1" strips wrapped like abr tape.
As onzadog, but I do apply wet, I find I get less bubbles - more time to adjust position, could be I'm just ham-fisted though... 😐
I've got loads of IPA, a microfibre cloth, hairdryer and some A3 paper to make some templates. The one thing I don't have is patience!
Heat the frame? Even a carbon one!? 😯
IPA, put on wet, don't stretch it too much or stretch it over concave curves. Use hot water to soften the tape, I certainly wouldn't hairdryer my own frame.
Wet method ?
Que?
scruff - MemberWet method ?
Que?
Posted 15 minutes ago # Report-Post
Utubes blocked.
Peel the backing off, then you dunk the tape in water (with a little fairy liquid) before applyin.
Apply tape and after squeegee the water out with a credit card. Makes applying easier as its slips around on the bike.
Of course you have to leave it to dry for a while.
Wet application (I have done it) is absolutely **** for anything apart from top tube, downtube and maybe fork stanchions. Everything else apply it dry and just be f'ing careful.
Well I tried the dry method, made up some templates, got the hair dryer out, heated the tape.. Stuck it on...
I'm now giving up and not using any heli tape! I struggled with just a fork leg! The power bulges created loads of creases and bubbles. I might give the wet method a go this evening, but I can't see it being any better.
Also the frame has a matt finish, so I can't imagine it looking very good with the shiny heli tape over some bits.. Here's the bike I'm trying to tape.
Does anyone know of any LBS's that offer a heli taping service!? 😆
