                    Non overdrive Giant Anthem 29 2102/13? I want an angle headset.  https://www.superstarcomponents.com/en/slackerizer-angle-headset.htm
The steerer looks like a semi integrated with a top bearing 42 outer 31 inner and bottom 52/40 ish. Frame steerer length is 106mm.
Is that enough info to work out what I need?
                            Posted : 25/11/2020 1:30 pm
                    I believe you want the ec44 zs56 tapered in appropriate length for an anthem but not sure.
T7-2 on that list.
Make sure you've 2 spacers under your stem at present.
                            Posted : 25/11/2020 1:32 pm
                    20 mm of spacers under stem.
                            Posted : 25/11/2020 1:36 pm
