HEadset questions, ...
[Closed] HEadset questions, S Works 2016 Enduro
11 Users
Morning crew,
I bought one of these headsets the other day after being linked from another site.
https://www.edgesportsuk.com/store/components/specialized-bikes-replacement-headset-bearings.html
Now, the OD and the ID seem correct. But i'm struggling to see the H being right, compared to what i have fitted already anyway.
According to the digital verniers, my H on the fitted bearing is 7.1mm and the H on these is closer to 8mm.
When i fit the plastic/rubber top cap, i have a bit of 'space' as the cap is fairly flat.
On my G-160 the surrounding cap above headset has a rubber ring, which i'm assuming is basically acting as a cover and compresses to seal it, but the specialized isn't quite as rubbery/fitting.
Sadly the lettering on the bearing that's on the bike has completely worn off, so i can't really get anything off it, but if you look you can hopefully see what i mean.
Fitted headset.
[url= https://live.staticflickr.com/65535/50515092778_cc117b51e5_b.jp g" target="_blank">https://live.staticflickr.com/65535/50515092778_cc117b51e5_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXR4au ]2020-10-22_09-37-35[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
New headset
[url= https://live.staticflickr.com/65535/50515095003_efbd1f8768_b.jp g" target="_blank">https://live.staticflickr.com/65535/50515095003_efbd1f8768_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXR4PR ]2020-10-22_09-38-38[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Headset comparison
[url= https://live.staticflickr.com/65535/50515979887_c1a97cb7ca_b.jp g" target="_blank">https://live.staticflickr.com/65535/50515979887_c1a97cb7ca_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXVASt ]2020-10-22_09-38-49[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
So it could be i'm making something out of nothing here and it's simply the dust cover, then we're all good. I can steal one off another bike for now and use that.
But just wanted to run it by you guys first as you know more about this stuff than i do.
edit: all of the searches i find show the headset as H:8 which is what was sent, so i'm hoping/guessing i'm just reading more into it than i need to.
Cheers.
Posted : 22/10/2020 9:41 am
Hope he is still liking it, that second photo doesn't look right to me. I've double checked every bike in the garage, all have the same headsets and none are sitting proud like that.
These are who we use for replacement bearings.
https://trailvision.co.uk/collections/blueseal-headset-bearings/products/specialized-enduro-headset-bearings
The numbers are in the drawings at the bottom, I know that TH870E and TH073E fit in ours and non stick out like your photo
Posted : 22/10/2020 11:50 am
Looks like the new bearing you have bought is not the correct bearing for the frame, or you have some 'debris' in the headset cup that is preventing the new bearing from sitting correctly.
Posted : 22/10/2020 12:01 pm
I would be ringing Edgesport up and checking the number on yours is right for the bike. I would ask them to confirm the number is compatible with TH870E
It needs to be a campy fit, their link on ebay gives MH-P08F and not H like on your photo. I wouldn't run it like that.
Posted : 22/10/2020 12:13 pm
Hope he is still liking it, that second photo doesn’t look right to me. I’ve double checked every bike in the garage, all have the same headsets and none are sitting proud like that.
So, I took it to lbs and he thinks it's fine but fitted a smaller stack top crown race which makes it look right. He feels the bearings are correct, just an aesthetic issue more than anything else.
I've also ordered the bearings you linked to just in case. As well as emailing Edgesports. So all bases are covered.
He's loving it thank you. Having a blast. Hopefully he'll be jumping the hell out of it Sat but he's down with some lurgy at the moment so not sure.
Posted : 22/10/2020 12:52 pm
Glad he is. The top crown race is a Specialized fitted one, did yo get it back from the bike shop for if you need it when the new bearings arrive.
It doesn't look aesthetic to me and looking at all our others, you may be lucky and have the new ones before the weekend. If it was me I would stick the old one back in until I was sure. As the bearing sits direct onto the carbon its a risk unless you are 100% certain.
Posted : 22/10/2020 1:16 pm
Tracey's correct, the top cap on the Enduro should be flush, and shouldn't be replaced. It's the wrong bearing if it doesn't fit.
I've used trailvision's sets before and they just drop in, no worries, and everything goes back without any gaps.
Posted : 22/10/2020 1:19 pm
The bearing you've fitted is a TH870E (Campy style bearing), so good for the upper, at least you'll have a spare now as these things go quite regularly!
Posted : 22/10/2020 1:27 pm
If its the right bearing it should not be sticking out as proud as that so something doesn't look right
Posted : 22/10/2020 1:56 pm
LOL i'm lost now... So yeah i'll fit the old one (Have to go and collect it) for now until the other one you linked earlier arrives, we can never have too many bearings after all 🙂
Posted : 22/10/2020 2:02 pm
You have the wrong bearing, you need this one, your original top cap and compression ring...
This one
Maybe a better LBS as well!
Posted : 22/10/2020 3:09 pm
Right, so... here's the standard headset as supplied.
[url= https://live.staticflickr.com/65535/50516590466_364a2bc57e_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516590466_364a2bc57e_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXYJnG ]2020-10-22_03-25-53[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
[url= https://live.staticflickr.com/65535/50516590146_73a1cb4e7f_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516590146_73a1cb4e7f_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXYJhb ]2020-10-22_03-25-47[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Now there's no way in the world that's flush... and no way in the world it can go in any other way, at all. It' completely in the recess
This is it with the crown/compression/whatever ring
[url= https://live.staticflickr.com/65535/50515877223_3be1e2faea_b.jp g" target="_blank">https://live.staticflickr.com/65535/50515877223_3be1e2faea_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXV5mp ]2020-10-22_03-25-42[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
This is the 'new' headset and lower stack crown/compression/whatever
[url= https://live.staticflickr.com/65535/50516589361_1a65f1f45c_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516589361_1a65f1f45c_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXYJ3D ]2020-10-22_03-25-32[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
I don't see what i'm missing here, but none of them are ever going to be flush no matter what i do
Posted : 22/10/2020 3:29 pm
I guess you will need to reassemble with the fork and stem using all the original parts, cleaned and greased (especially the inner face of the bearing and outer of the compression ring). The compression ring should close up (compress if you will!) and thus sit lower in the bearing, which I can see is the lipped type.
If that works then you know which bearing to buy, if it doesn't then there is an error in the assembly.
As I side note I have a Stumpy that uses the same bearings BUT has a flush fit top cap so the bearing sits a bit lower, your top cap doesn't look to be a flush fit one.
Posted : 22/10/2020 4:24 pm
When i fit a top cap/dust cover, it all looks lovely. No issues at all that i can see with it....
I can't see any way that bearing is going to sit lower, it's as far in as it's getting.
[url= https://live.staticflickr.com/65535/50516097893_a5341dd032_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516097893_a5341dd032_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXWcX4 ]2020-10-22_04-35-16[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Taking my Parkwood apart, the headset sits above the frame too.
[url= https://live.staticflickr.com/65535/50516823936_eafd50ae35_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516823936_eafd50ae35_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXZVM3 ]2020-10-22_04-38-29[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Posted : 22/10/2020 4:36 pm
Using a metal tapping implement, i'm sure my headstock is alu ?
Posted : 22/10/2020 4:52 pm
steel4real
You have the wrong bearing, you need this one, your original top cap and compression ring…
This one
That's the same as he's bought, a TH870E, from what he's given in the picture response it all appears to be right, the top cover appears to cover the bearing and allows it to do the job, i.e. preload the bearings prior to tightening the stem bolts, unless i'm missing something?
Looking at the original picture again, they actually look the same size, the 8mm is from the top to the start of the chamfer, not overall, the old bearing looks like it would be a shallower fit in the frame, but the flat edge looks about the same.
Posted : 22/10/2020 5:50 pm
Without stripping a bike to get pics with the cap off I cant say.
What I can say is that I've just rechecked every Stumpy, Enduro and Levo in the garage that has the Blue Seal bearing in from Trail Vision and they all look the same with very little, if any, gap. The Levo pic has the original Specialized bearing fitted. They all have the standard Specialized top cap bearing cover fitted.
I have taken the pics below of a couple of them and also zoomed in best I can on the Enduro photo and they all confirm what is should look like.
The gap in your first posting just dosent look right. Have you had anything back from the Suppliers yet.
Posted : 22/10/2020 6:13 pm
[url= https://live.staticflickr.com/65535/50515979887_c1a97cb7ca_z.jp g" target="_blank">https://live.staticflickr.com/65535/50515979887_c1a97cb7ca_z.jp g"/> [/img][/url][url= https://flic.kr/p/2jXVASt ]2020-10-22_09-38-49[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
The inner race on the old bearing looks like it sits a lot lower than on the new one.
Posted : 22/10/2020 6:22 pm
All your pics look like the top covers are 1mm or 2mm high, so preloading the bearing into the recess, Steve's FSA is about 4mm, also looks like the cover is a snug fit to the frame in the built up pic, so would guess the top of that cover is what preloads on the bearing.
Posted : 22/10/2020 6:31 pm
I think we're agreed that the first bearing is potentially too tall... but i'll be most curious to see what the postman brings from your supplier as H:8 implies a height of 8mm, which is what the bearing from Edgesport actually is... However, i can't see anything that shows a H:7 which is what the one fitted seems to be.
No matter what though, unless the height was 5 then it's not going to fit flush in the recess.
Posted : 22/10/2020 6:36 pm
All your pics look like the top covers are 1mm or 2mm high, so preloading the bearing into the recess, Steve’s FSA is about 4mm, also looks like the cover is a snug fit to the frame in the built up pic, so would guess the top of that cover is what preloads on the bearing.
The bike did come with a flatter one.
[url= https://live.staticflickr.com/65535/50516969732_b600b56c2f_b.jp g" target="_blank">https://live.staticflickr.com/65535/50516969732_b600b56c2f_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jY1F7L ]2020-10-22_04-31-32[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Which is what i've refitted today, but that's basically just a piece of plastic, a dust cover for want of a better phrase, i can't see how that can preload something correctly ?
Posted : 22/10/2020 6:39 pm
The Enduro came with the Specialized top cap as have all our others. They are all of the same design and all work as they should.
The gap in the top pic looks wrong to me, why its like that after swapping out a bearing I don't know. My suggestion was to put it back as it was, bearing, top cap crown race thing and original top cap cover and then work back from that. Thats what I would do to find out whats not right.
Posted : 22/10/2020 6:52 pm
The gap in the top pic looks wrong to me, why its like that after swapping out a bearing I don’t know. My suggestion was to put it back as it was, bearing, top cap crown race thing and original top cap cover and then work back from that. Thats what I would do to find out whats not right.
I have 🙂 See the previous post to yours 🙂
Posted : 22/10/2020 6:54 pm
Starting to look like new bike time!
These are the bits you should have.
https://www.cyclestore.co.uk/specialized_enduro_stumpjumper_headset-ID_76775?sv_source=google&sv_medium=cpc&sv_campaign= [campaign_name]&sv_term=[keyword]&gclid=Cj0KCQjw28T8BRDbARIsAEOMBczEG7hMxVBPH48P2uCEp_aB7aQusebzxLHPBWX3o4eHTCq7pRzJzs8aAijFEALw_wcB
Disregard the bottom two bits and you should have a bearing, top cap, top cap crown race and top cap washer.
The preload on them and the bottom bearing should come from the tightening of the star nut. It also looks like all the spacers have been removed but that shouldn't alter much. However I would stick the spacers back in to eliminate that.
If you go back to this then the gap should then be the same as before
https://singletrackmag.com/forum/topic/incoming-small-boys-bike-specialized-enduro-s-works/
Posted : 22/10/2020 7:05 pm
I deffo didn't/don't have the washer.
The spacer is up top but still present
Posted : 22/10/2020 7:16 pm
Its usually stuck to the underside of the top cap with grease. If you arnt carefully or didn't know it was there or more usually the bike shop didn't know it there's a good chance its fell off some where when its dismantled or its still stuck on with grease.
When you put everything back together as it was has the gap closed back to where it was.
Posted : 22/10/2020 7:25 pm
Yeah.
Posted : 22/10/2020 7:30 pm
So if the only difference is the new bearing and top crown race then it points to one or both not been right.
All my spare bearings are in the camper, not at home, or I would have posted one down so you would have had one for tomorrow.
I didn't realise that the pads fitted were finned and the spares I gave you were not for the finned type. So they will be fatter and if fitted with finned backs won't work. If you need any of the race matrix for that which fit the fins let me know and I will send some down.
Posted : 22/10/2020 7:49 pm
It's got the standard crown race on top, so we're pretty sure the bearing is the issue.
Honestly you've done plenty don't worry about bearing sending or pads, we're both happy.
The bearing works, I just wanted a new one, which I'll have soon enough.
Posted : 22/10/2020 7:55 pm
OK keep us up to date with the rides.
We are now stuck with riding in South Yorkshire from Sunday. Will need to get back to riding local for the foreseeable future
Posted : 22/10/2020 8:02 pm
He's down with lurgy so no riding for him at the moment. I'll be out though
Posted : 22/10/2020 8:04 pm
Looking on the full headset link, that dust cap spacer is one of these.
https://www.ebay.co.uk/itm/FSA-Integrated-Headset-Micro-Spacer-10-pack-1-1-8in-x-0-25mm-MW0006-Silver/143742270915?hash=item2177b4fdc3:g:jZEAAOSwLGRfY4gZ
Sadly, i only really need one of the sods, not 10 lol. The search continues, or i'm buying a pack of 10.
Ah well, can never have too many random bits... bought 10 of them.
Posted : 22/10/2020 8:26 pm
The new bearing in your picture is MH-P08H8, (8mm height) you can get a 7, 7.7 or 6.3 as well.
Just make sure you know if you need a 45/45 or 36/45
https://www.kineticbikebearings.com/catalogsearch/result/?q=p08
Posted : 22/10/2020 9:53 pm
Thank yiu
Posted : 22/10/2020 9:58 pm
The link Tracey provided pointed to the TH870E being the required bearing, this is the 8mm height bearing, TH873E is 6.5mm high, but does not appear to be listed for the 2016 enduro headset, so i would be wary of fitting something that may cause issues with being preloaded as required.
It might be worth putting some more detailed pics of the frame headtube without a bearing inside to see if there is an issue, as all info on the normal sites point to the bearing you bought being the correct bearing, so that 45 degree chamfer should fit neatly into a similar chamfer in the head tube, leaving 8mm or so of space for the rest of the bearing to snuggly fit into.
Would be good to have a look at this, it's a weird one, might be worth getting a bike shop (or another one) to have a quick look, maybe even depth gauge the height sans the chamfer in the frame.
Posted : 22/10/2020 10:38 pm
Honestly, the frame is clean as a whistle inside. THere's no dirt, no mess, nothing protruding
I won't be fitting anything i'm not 100% happy with, hence how all this started 🙂
I think i've got a total of 3 other top bearings arriving in the next day or 3 now, so we'll see what comes, how it looks and how it fits. I don't need the bike this weekend, so can just crack on and check and test stuff.
That's the main confusing part... because the bearing that's fitted is NOT 8mm in height, it's just not, my calipers have that as 7.1mm.
But as i say, we'll see what comes in the post and compare stuff.
Posted : 23/10/2020 7:30 am
Angle/height of internal race meaning the wedge won't sit right.
Posted : 23/10/2020 7:54 am
Angle/height of internal race meaning the wedge won’t sit right.
Sorry ?
[url= https://live.staticflickr.com/65535/50515812266_cd71203817_b.jp g" target="_blank">https://live.staticflickr.com/65535/50515812266_cd71203817_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jXUK3s ]2020-10-22_09-40-08[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
If we look at the old and the new, we can see that the angle of 45 and the length of that appears the same.... It's the vertical height that's different from there. Along with the internal height.
So today i've got a bearing from Kinetic along with the set from Trailvision hopefully on their way. I'll then get the measurements and see where we are.
Don't forget, this isn't urgent. The bearings in there still fit as they did and work as they should 🙂 I just wanted new bearings, but the bike is perfectly usable 🙂
Posted : 23/10/2020 7:59 am
Ah, you'll find the best fit, the other might be a TH873E, so 6.5mm height, https://www.wychbearings.co.uk/ACB4545-1125.html, this one is also an angular contact bearing, so should work a little better for headset upper bearing.
Posted : 23/10/2020 8:55 am
Thanks mate..
I'll see what the one Tracey linked to comes as first. Then go from there, that's the one they use on all the Enduros... so i'm hopeful 🙂
Posted : 23/10/2020 9:06 am
If it stops raining here, I'll check mine and see what the height is.
Posted : 23/10/2020 9:10 am
If it stops raining here, I’ll check mine and see what the height is.
What model do you have Nick ? That would be very much appreciated 🙂
A pic of how it sits in the frame would be good too 🙂
The Trailvision are now showing as shipped, so i won't see today.... But doesn't matter as today is 3M heli tape day 🙂
Posted : 23/10/2020 9:11 am
MIne's a pro, same front triangle as Tracey's, but without the fancy decals...
Posted : 23/10/2020 9:31 am
Coolio... would be interesting to see/know then
Posted : 23/10/2020 9:32 am
So the trailvision/Blueseal bearings arrived as per Traceys link
[url= https://live.staticflickr.com/65535/50520067427_70e4df355a_b.jp g" target="_blank">https://live.staticflickr.com/65535/50520067427_70e4df355a_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jYhxXi ]2020-10-23_01-22-30[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
[url= https://live.staticflickr.com/65535/50519179613_13af670741_b.jp g" target="_blank">https://live.staticflickr.com/65535/50519179613_13af670741_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jYd13a ]2020-10-23_01-24-39[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
As you can see, they're exactly the same as the Edgesports bearings, i mean EXACTLY...
[url= https://live.staticflickr.com/65535/50519900541_847bb27b52_b.jp g" target="_blank">https://live.staticflickr.com/65535/50519900541_847bb27b52_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jYgGkX ]2020-10-23_01-25-25[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Both though are completely different to the bearing that came with the bike. Both in terms of height externally and height internally.
This is as you can see, the inside of the frame/headstock
[url= https://live.staticflickr.com/65535/50519196603_b0949b1bf0_b.jp g" target="_blank">https://live.staticflickr.com/65535/50519196603_b0949b1bf0_b.jp g"/> [/img][/url][url= https://flic.kr/p/2jYd666 ]2020-10-23_01-29-22[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
In all honesty, i'm at a bit of a loss now in terms of how to progress lol.
If i fit either the Edgesport or the Trailvision bearings, then they're tall in the frame and to completely be covered would need a taller dust cap, otherwise we've got a gap there...
I'm going to drop into Specialized a bit later and see their thoughts as i've got to shoot into town anyhow.
For a point of note... EVERYTHING is now back as it was when the bike first came to me..
Posted : 23/10/2020 1:33 pm
Ah i see whats happened here, youve got the wrong bearings 🙂
if you look att he first one youll see its got a ledge on the inside. this means that the headset sleeve fits slightly deeper into the bearing and consequently the whole thing pulls down.
hope that helps
Posted : 23/10/2020 1:57 pm
been there before
https://photos.app.goo.gl/2C1RM2hHxrr7xoC48
Posted : 23/10/2020 2:00 pm
Nah, i'm still lost here. Sorry. I've got 2 sets of the bearings that are the ones people have said i needed. I'll be the first to admit, they're slightly different to the one that the bike came with, but i have no concept of what that one is as there's no words and letterings on it...
I'm looking at your pic, but still can't see the difference between them.
Posted : 23/10/2020 2:05 pm
OK, before clicking that and being another bearing and £18 in the hole, i'm going to drop into Specialized and see what they say, just had a chat with the workshop fella there.
He said "there can be a small gap between the dust cover and the frame, which is normal".
I guess we'll see what he thinks when i get down there.
Posted : 23/10/2020 2:13 pm
yea the inner race should have a step on it. yours doesnt appear to?
Posted : 23/10/2020 2:23 pm
So specialized confirm I have the right headset in the 8mm and it's purely a cosmetic thing we're fixing and we're happy with a lower stack compression ring on there with 8mm bearing.
They're fine with bearing protruding as that's normal he says.
So we're all good and now have about 3 sets of bearings in spares for the coming years ha ha.
Posted : 23/10/2020 3:29 pm
Glad to hear that. I still can't figure out why the topcap gap is there. Next time we change one or service it I will get a photo of whats under it to compare with your pics.
Hope the invisiframe goes to plan
Posted : 23/10/2020 3:48 pm
Most of the frame was already done by you guys, just chainstays etc and a few contact points.
Posted : 23/10/2020 3:50 pm
Can confirm that my bearing looks like the one from Trailvision. although mine measured with calipers is 7mm.  top-cap fits snugly with no gap. Also the bearing sits directly onto the carbon of the head-tube rather than a metal insert.
sounds like you got it sorted anyway.
Posted : 23/10/2020 4:23 pm
I've been up to the camper this morning to drain it off as we can't go out of South Yorkshire in Tier 3.
I've fetched back my bearing box and checked the six that are in it.
For those that are interested
There are 2 new from Trail Vision that are stamped up as per their site. Both measure 7.78mm
There are two new Specialized ones with no stamps on them. Both measure 7.76mm
There are two original used Specialized ones. These are what have been swapped from Abigales race bikes but are two good to dump so will be used for spares if needed. One measures 7.56mm and one 7.61mm
I've also had a long chat with a Mechanical Engineer who was not suprized at the difference.
He recons a used bearing will always measure less due to less grease and also slight wear.
Not sure if he's right or not but it may be the reason
Posted : 24/10/2020 11:27 am
To be fair, you have 3 sets of TH870E bearings, you might just make it to Spring with a working headset ;o)
Posted : 24/10/2020 2:18 pm
Are they common to go then?
I replace my headset bearings in the Whytes about 18 month/2 years, certainly not that regularly.
Posted : 24/10/2020 2:26 pm
No ours haven't and get used all year round. The Trail Vision/Blue Seal ones are supposed to be packed with marine grease.
If any thing we have changed the bottom ones after a wet and muddy Peak winter and then probably didn't need it.
The four that are Specialized supplied ones have no markings on them so no idea of what brand or number they are.
They Engineer I had a chat to was very informative on how the top cap, top crown race and inner bearing work and why it should be a little proud of the frame, also why it should be rechecked after its bedded in.
Posted : 24/10/2020 2:53 pm
Excellent.... We're all good then 🙂
His is ready to roll.
Posted : 24/10/2020 3:09 pm
Thats good, hope he's feeling a bit better.
I had a very nice gin and T last night with a slice of frozen grapefruit in it.😉
Posted : 24/10/2020 3:12 pm
I had this with an older enduro expert, tried various bearings but all left a small gap when top cap was fitted. Bikescene in Guisborough saved the day, knew exactly what I meant as soon as I started to describe the problem, the lad disappeared into the workshop and returned with a bearing without me actually finishing what I was trying to describe. Perfect fit and lasted the rest of the time I owned the bike
Posted : 24/10/2020 3:19 pm
Top bearing generally lasts OK but IME the bottom one can take a hammering, last one fell apart as I took it out, so I normally check every few months to see if it looks OK. currently has a CK lower in to see if it lasts a bit longer.
Posted : 24/10/2020 4:12 pm
Yeah I don't mind getting 6-12 months, it takes minutes to change, just the way it was said earlier I thought they may be more common.
I've got 2 full sets in spares for the S Works and the G160 so no worries at all
Posted : 24/10/2020 4:15 pm
After i emailed Edgesports, they called me today. We discussed everything and anything possible about the headset, then he picked out 3 potential options of bearing and is sending all 3 in the post completely free of cost, for me to test out and decide which i want to run for the future.
The headset is currently set up as per Specialized bearings. The only thing i don't know 100% is the compression ring, so i'm running the lower one of the 2 i have here. I've also got the 0.25mm spacer fitted under the dust cap, again as per Specialized instructions.
We'll see what the postman bring and what i decide to do next with it 🙂
Firstly though is dirt and mud in FoD on Thursday.
Posted : 27/10/2020 1:13 pm
I know this is dragging on, but may be useful to someone on the internet one day.
I got the 2 new bearings from Edgesports, but if i'm honest, neither really fit the bike any better than the one that came with the bike originally.
So i've sent their 2 bearings back, along with sending the one that was in the bike to them to see if they can match it up. If not, i'll just keep running the one that is the dimensions from Specialized. All good fun though.
Posted : 05/11/2020 4:06 pm
