Headset problem.
[Closed] Headset problem.
3 Users
The bottom bearing on my YT has seized up and won't spin at all...I have been on to YT who recommended that I get one of these
https://shop.acros.de/headset/zs/4563/az-56-headset
I would only be able to buy this from Germany with heavy shipping costs and I'm wondering if I could use a Cane creek or hope that I could buy in the uk that would do the same job?
Posted : 30/05/2018 8:32 pm
Just replace the bearing cartridge. No need for a replacement headset/cups, unless you want to change the headset for some reason.
Posted : 30/05/2018 8:36 pm
Well hope do mix n match, so you'd probably be able to just get the lower part of it is just the bottom bearings?
Posted : 30/05/2018 8:40 pm
It is the bottom bearing, the top is good. Just need to make sure of the right spec, if I go for different brand.
Posted : 30/05/2018 8:50 pm
