Headset help
[Closed] Headset help
2 Users
I need the correct Hope pic n mix headset for the following
Headset-Upper: ZS44
Headset-Lower: EC44
Am I right in saying it’s 2H
It’s to fit my Salsa El Mariachi frame for a straight 1 1/8th steerer of the firestarter fork
Many Thanks
Posted : 23/11/2019 7:22 pm
2H seems correct for what you said you need, which is a zero stack top race and external cup on the bottom which is a 1.5” So if you want to run a straight steerer you will also need a HS136. If you haven’t seen it I find the hope technical guide quite easy to follow
Posted : 23/11/2019 7:39 pm
Thank you just had a look at the guide. Brilliant way of explaining it. Now bookmarked.
Posted : 23/11/2019 7:54 pm
