Headset headsore
[Closed] Headset headsore
4 Users
So I am now the proud owner of a 2013 Specialized Camber Comp frame ready for the winter project. While I wait for the frame to arrive I am of course working out all the details ready for the build. So my question is; What Hope pick and Mix headset do I need?
From Specialized website it a "Campy style upper with 1-1/2" lower, cartridge bearings" which is not really much use and I am really getting confused!
Can anyone shed some light on this?
Thanks in advance!
Posted : 06/12/2015 3:45 pm
[url= http://www.canecreek.com/headset-fit-finder ]Try this page as a guide to the SHIS numbers[/url]
Posted : 07/12/2015 6:11 am
I think they're like the stumpys, where just the bearings drop in. The headset cups are already a part of the frame. [url= http://www.edgesportsuk.com/store/index.php/popular-products/specialized-fit-headset-bearings-11-8-1-5-tapered.html ]Something like these.[/url]
Someone with the bike should confirm though!
Posted : 07/12/2015 10:15 am
The bearings should just drop into the frame on a 2013, bog standard 45° 1.5 inch cartridge for the bottom and a 45° 1 1/8th on the top, dimensions below, or go and ask Adam next time you're in BS 😉
Upper bearing OD=42 x ID=30 x A=45° (for 28.6mm / 1 1/8th upper steerer)
Lower bearing OD=52 x ID=40 x A=45° (for 38.1mm / 1.5 lower steerer)*
*assuming you're going to use a tapered fork, if you want to use normal you'll need
for future ref, this [url= https://www.canecreek.com/headset-fit-finder ]headset finder tool on cane creek website[/url] is useful
If you don't have the crown race and upper assembly and need a full headset then look for one that uses the above bearings.
Posted : 07/12/2015 10:33 am
Example ones that will fit from Cane Creek is
Cane Creek 40 lower - IS52/40/H1
part number BAA0086
[url= http://www.chainreactioncycles.com/cane-creek-40-series-is52-40-bottom-assembly/rp-prod115643 ]http://www.chainreactioncycles.com/cane-creek-40-series-is52-40-bottom-assembly/rp-prod115643[/url]
Cane Creek 40 upper - IS42/28.6/H9/K
part number BAA0094K
[url= http://www.chainreactioncycles.com/cane-creek-40-series-is42-top-assembly/rp-prod115645 ]http://www.chainreactioncycles.com/cane-creek-40-series-is42-top-assembly/rp-prod115645[/url]
Posted : 07/12/2015 11:07 am
