Hi,
As title, Im after suggestions of what other headsets (apart from Nukeproof own) I can run on a Mega for a tapered 150mm fork. Nukeproof's website state that for a 150 fork it will have a internal top cup and external bottom.
Bearing in mind that the headtube is 1.5".
Thanks
Whats wrong with the NP ones?
When you say bearing in mind the head tube is 1.5" do you actually mean the head tube of the frame? if so its not 1.5" its 44mm.
Just keeping my options open, NP ones seem expensive.
1.5" is the headset size ....
get yourself some 1.5 Lyriks.
150mm forks don't to justice to the Mega Frame...
I'm not sure I understand the question. The mega is a 44 headtube standard. If you are unsure of the size, go to the cane creek website and choose another bike with a 44 head tube (e.g. a Turner 5spot). Get a zero stack top and a external bottom cup.
You can choose any headset you want which fits. I've put a cane creek one on mine.
