looking for som brakes for a pivot mach 6, also looked at magura mt7, but the plastic master cylinder scares me a bit.... feel free to give som advice!
No love for hayes !?
Just ordered a set, will let you know in a week.
Thanks guys !
Can highly recommend TRP Quads
Although switch out pads for full on metallics and get them bedded in properly from get go!
They work real nicely to bite on Hope rotors
However the floating rivets there is lil foul play so don't expect flush clearance
Thanks guys!
Some info about Magura brakes.
Thanks paton!
Hello sunnrider
Any updates on the hayes...?
Did you bleed them...?
Jesper
Hey. Got them, swapped them out with the Hopes I had on and so far loving the difference. On a really familiar bit of downhill track I was able to brake a bit later than previously with no issues.
The lever action is so much smoother, it takes no effort at all and one finger braking is fine, even though the lever is a a bit bigger.
Out of the box I just fit them with some tape to get the sizing right, then bled them whilst off the bike.
The bleeding process is a little longer than with other brakes if you do the whole thing, but it gave me a good result first time. I just followed the online vid from Hayes. I'm running them with Hope rotors and they fit, no rubbing.
Yeah sound good,
My TRP quad levers are huge boxey items
They sound spot on the Hayes - I would deffo mount a set 👍😜
Nice sunnrider !
