Hayes brake lever s...
[Closed] Hayes brake lever swinging forward ~howdo I stop it?
4 Users
I have hayds soles and 1 lever is obviioq missing something.... How do istop it swingingforwaard
Posted : 31/10/2013 6:56 pm
At a guess the push rod is on the wrong side of this,[url= http://www.chainreactioncycles.com/hayes-retaining-washer-hfx-9-so1e/rp-prod20143 ]retaining waher[/url](washer held in with a circlip)
Have you had a crash that pulled the lever forward?
Posted : 31/10/2013 7:17 pm
Yep, ball-end of the push-rod has almost certainly pulled through the washer.
It's easy to replace the washer, but you will need a set of small circlip pliers (although I have done it a few times with 2 nails and patience!).
Posted : 31/10/2013 8:02 pm
These washers have a habit of cracking and used to only be found in the £35 master cylinder rebuild kit. I have lucked out and found some normal washers that had the right diameter - but you did need to make a little stack of them.
Posted : 31/10/2013 8:46 pm
Thanks all,yup the washer has gone,hopefully all orted now,cheers
Posted : 31/10/2013 9:26 pm
