I need to get hold of an adapter to connect the hose to the master cylinder/lever. Do I have any alternative to buying the wildly expensive official kit?
Do you really need it?
As you push the fluid up from the piston*, if you take out the plug out & carefully mop up the excess fluid as it comes out...
* Well that what you do with my 9's anyways.
Well not *really* and that's what I'm going to do as a last resort - but an adapter would allow me to attach a tube though which is cleaner and you can see bubbles better.
Dunno what that is (yes ok, it s a Hayes stroker bleed fitting), what he actually after is the metal thing with the spring (no idea what the spring is for), as per this;
http://www.chainreactioncycles.com/Models.aspx?ModelID=8384
I just use a length of pipe with a small "V" cut out, this lets the tube squeeze into the bleed hole, never had a spill yet.
Actually it was jims link that I was after. I had already found it but thanks anyway.
I stand corrected, but TBF I did make mention that it was the 9's I knew about...
You can find our Hayes Stroker specific bleed kit here if it helps:
http://www.epicbleedsolutions.com/products/bleed-kits/hayes/stroker/basic-kit/
Also available with brake fluid.
Thanks for the info EBS, but please keep up at the back 😉
