Have you installed ...
[Closed] Have you installed raceface chainrings in a 2x10?
2 Users
I am trying to replace my truvativ chainrings.
This is the current spec:
CHAINRINGS38A x 24A, carbon shift guard, 4-bolt, 104/64mm
On a SRAM crankset, Carbon S-2200, 10-speed XC Trail double, GXP spindle, removeable spider
SRAM x7 2x10 front mech
A friend has offered me 2 raceface 10 spd turbine chainrings, 24t and 36t, but on the rings they say "no SRAM 2x10". The rings originally came on a different crankset.
I was wondering if the no SRAM message might only be in ref to the original cranks or if it refers to the actual rings themselves...
I have seen the raceface PDF with FAQ, but I am unsure if my setup counts as a double or a 2x10...
If it's a double then no go, but according to th chart 2x10 is ok...
Any advice most welcome!
Posted : 27/04/2014 9:18 am
I suspect the message refers to the original SRAM double 120/80 BCD. If your cranks are 104/64 they should fit.
However, my mate had RF cranks and he reckoned the rings have the wear resistance of cheddar. Middleburns?
Posted : 27/04/2014 9:32 am
Thanks - middleburns? Fit SRAM x7 then...
Posted : 27/04/2014 10:37 am
