Harsh feeling Fox 3...
[Closed] Harsh feeling Fox 38?
14 Users
Ive got a Fox 38 performance elite on my Levo and have set the sag and then followed the fox recommendations for rebound and compression.
It feels very harsh and occasionally on a big hit I've had my hands jolted off the bars?
Which setting do I need to look at to prevent that happening HSC, LSC or HR, LSR?
The fork feels very different to the 38 I had on my last bike but that was a cheaper model?
Any ideas?
Thanks
EDIT: SAG !!
Posted : 19/11/2021 11:23 am
Maybe spent a bit more thyme making sure your sage is correct.
Jokes aside, sounds like more (slower) rebound needed
Posted : 19/11/2021 11:28 am
🙂 Good skills lol
So do I need to make the fork slower to rebound?
Posted : 19/11/2021 11:30 am
A harsh feeling fork could be due to any of the adjustments, so too much or not enough pressure, compression damping not allowing the fork to move, rebound too fast so pushing back or slow so packing down. And that’s before you even take into consideration what the rear is doing to effect the front. As you’ve got all the adjustments you’ve got to spend plenty of time fiddling with it.
I’d start with both compressions open and play with pressure first. Just remember that changing pressure will also effect rebound speed
Posted : 19/11/2021 11:54 am
What's the bushing clearance like? Can't remember the last time I checked a fork and didn't need to do a bit of tweaking.
Posted : 19/11/2021 11:59 am
I’d have thought hands jolted off bars (assuming it’s as you hit the compression hard) mean you’ve got too much high speed compression damping on there - stopping the fork using as much travel as it could do. It controls high speed piston movements - like landing a drop or jump.
Lsc is more about diving / bobbing.
Rebound more likely to cause the fork to pack down over repeated bumps if it’s too slow.
Whilst it’s Cane Creek - I find this is a useful basic guide to symptoms / what to do to correct them. I think you’ve got too firm a feeling from your description:
[url= https://i.postimg.cc/MpVdP9fL/659DB73D-B9F9-4837-9F15-6C22AF76ED56.pn g" target="_blank">https://i.postimg.cc/MpVdP9fL/659DB73D-B9F9-4837-9F15-6C22AF76ED56.pn g"/> [/img][/url]
Posted : 19/11/2021 12:03 pm
Have you tried the baseline settings from fox? If not it’s a good starting point and I often don’t need to vary much from
it
Posted : 19/11/2021 12:23 pm
I had this o a 38 too. The lower air side chamber had way too much grease in it. Stripped & clean it. Much better. Upgrading to the posher damper unit really helps. My take is that the fork is over damped as it comes - for a lightish slow rider. Try no compression damp & just a few clicks on rebound. Worth experimenting... I found Fox settings too stiff.
Posted : 19/11/2021 12:29 pm
Sorry just read your post again op
If the fork is way out despite using fox baseline settings I think I’d be searching for issues rather than tuning damping
Posted : 19/11/2021 12:30 pm
I was speaking with a bike mechanic up the Golfie the other day and he says all Fox forks are shipped with too much grease in the damper cartridge side. Only needs a slight coating and once removed and wiped off, his and plenty of other forks work as expected. Apparently Fox do this as a precaution because people don't always stick to the service intervals.
Posted : 20/11/2021 10:18 pm
What’s the bushing clearance like? Can’t remember the last time I checked a fork and didn’t need to do a bit of tweaking.
Can you explain what you are seeing and what home tweaking you are doing to the fork bushings to adjust the clearance?
Posted : 20/11/2021 10:28 pm
 poah
It feels very harsh and occasionally on a big hit I’ve had my hands jolted off the bars
what do you mean by harsh?
If your hands are getting jolted off then you don't have enough HSR
Posted : 20/11/2021 10:39 pm
Same as mentioned few times above, it may be too much grease in the air shaft on assembly. My 38 factory was harsh no matter what adjustments I seemed to make, but I noticed loads of grease when I was changing tokens. When I researched it, I found that this may be quite a common issue. I sent it off to tftuned for a service since sods law that the top end model needs a special tool or I would have done it myself. It came back a totally different fork and now feels amazing.
Interestingly they agreed that for lighter riders, the 2021 38 forks seem over-damped and too stiff. Not so bad with the 36 or heavier riders. Apparently the 2022 models have been altered to not be as 'spiky'.
Posted : 20/11/2021 10:57 pm
First thing i do is open up the compression, high and low, you're on an ebike, unless you're really wanting to firm it up on small and big hits for a certain reason (bike park stuff) compression isn't really your friend if you've got the right pressure in the forks.
After that, rebound, low speed first, then high, i tend to do this through the kerb drops, up to 1 metre drops or jumps, to make sure the forks are recovering in time for the next hit.
As others say, if that's not sorted it, then it may be time to get them to your LBS or wherever you bought them to check the inners, too much grease, hardened grease, etc can be an issue.
Posted : 20/11/2021 10:59 pm
If I strip the damper and air spring out of the fork as well as the foam rings and garter springs from the seals so all I have left is uppers, lowers and seals (or better still, during a seal change so the seals are out as well), the CSU should drop in under their own weight. Typically, they don't.
Most times, the bushings are too tight, and/or out of round. If so, I burnish them with a die 0.07mm greater in diameter than the nominal stanchion diameter. 35.07mm for my Rockshox and 34.07mm for my Fox 34s.
After enough passes, the CSU will drop in under its own weight and you get a much smoother, more supple fork action.
Posted : 21/11/2021 6:54 am
OP.
It's obvious you need a new bike to solve this problem.😜
Or just drop the lowers off and check for excess grease in the air side as a cheaper alternative.
Posted : 21/11/2021 10:39 am
If your hands are getting jolted off then you don’t have enough HSR
Could be either. I guess you’re assuming massive bottom outs? The opposite would be too much damping resulting in spiking (or something close to it) that will also be horrid but well before full travel
Posted : 21/11/2021 11:36 am
Not necessarily on bottom outs.
It tends to happen when I hit a rut or big root.
Yesterday I fitted a 170mm airshaft and removed two of the 3 volume reducers and give everything a good clean.
I've been up FOD today and it feels loads better. Coped really well with all the roots on freeminers.
I will give it a few more rides to bed in and go from there.
Posted : 21/11/2021 7:10 pm
