Does anyone have any experience of these halo hubs? Freehub was seized so trying to remove it but unsure how. Doesn't pull off. Should I remove the bearings and axle?
There is a hole in the side of the freehub so wasn't sure if there was some magic to do with that?
I'm probably missing something obvious but thought i'd consult the hive mind first before walloping things with a hammer.
[url= https://i.ibb.co/6BtfvS6/IMG-7472.jp g" target="_blank">https://i.ibb.co/6BtfvS6/IMG-7472.jp g"/> [/img][/url]
[url= https://i.ibb.co/rcxB41R/IMG-7473.jp g" target="_blank">https://i.ibb.co/rcxB41R/IMG-7473.jp g"/> [/img][/url]
[url= https://i.ibb.co/42HZXRJ/IMG-7474.jp g" target="_blank">https://i.ibb.co/42HZXRJ/IMG-7474.jp g"/> [/img][/url]
[url= https://i.ibb.co/48snKVp/IMG-7475.jp g" target="_blank">https://i.ibb.co/48snKVp/IMG-7475.jp g"/> [/img][/url]
Thanks!
Quick release ? - they will need a HEX key - usually 10mm in the drive side - tap the axel out from the drive side, pushing the non-drive bearing out. Looks like you've got all the 'cones/nuts off the axel.
Some freehubs unscrew from the non drive side and may use a 11 or 12mm hex key (my wife's hybrid does).
Thanks
Righto, looks like an 11mm hex (coming tomorrow) to get it off. Thanks for the help!
