GXP crank + Shimano...
[Closed] GXP crank + Shimano BB30 compatability?
3 Users
I've been running a Truvativ X0 crank on my hardtail with an external BB from Hope, plus the adapter to take the GXP crank.. However I'm about to purchase a new frame that has an already installed Shimano BB30..
So what do I need to get it to fit? I'm guessing putting the adapter rings in the new frame won't work!?
Or do I also have to buy a GXP BB30?
Posted : 29/11/2011 7:23 pm
Shimano don't do bb30.
There's pressfit bb90.
Theres bb30.
There's pressfit bb30.
What frame?
Posted : 29/11/2011 7:29 pm
I realised that after I posted, it's the Yeti AR-Sc frame..
Posted : 29/11/2011 7:32 pm
You'll be wanting one of these.
http://www.chainreactioncycles.com/Models.aspx?ModelID=55293
Posted : 29/11/2011 7:35 pm
Thanks a bunch! But, won't the bearings on that be terrible? Do I basically just need a GXP BB92? Although it's a 73mm shell width..
Posted : 29/11/2011 7:40 pm
Wait, so am I right in thinking that you can't run any GXP cranks on the frame at all..?
Posted : 29/11/2011 8:13 pm
What year?
I was under the impression it was bb92.
Puzzled I am.
Does it look like this? (bb is in)
Posted : 29/11/2011 8:42 pm
I'm really confused about this too.. it's 2009.
So I thought, ah, it must be the Truvativ GXP BB with ceramic bearings.. but that says it's for 92mm shells.. and in brackets says that standard GXP is 68 - 73mm shells.. so which is which?!
Confused.com
Posted : 29/11/2011 8:47 pm
It is BB92 (which is misnomer as the shels are 89.5mm or 91mm but we'll skip over that).
If it has threads its 68/73.If not its 92.
Posted : 29/11/2011 8:51 pm
that's it in the photo, yeh.
However, the description says it's press fit, which it is, judging by the picture, but also says it's a 73mm shell..
Posted : 29/11/2011 9:36 pm
AOB, your not being very clear. what says its a 73mm shell, the frame or the BB?
Posted : 29/11/2011 9:44 pm
Sorry.. i msorry i mean the description says its a 73mm shell in the specs of the frame.. but says its press fit in the description of the frame
Posted : 29/11/2011 9:53 pm
Thats just the Yeti I.T web guy being dumb. The press-fit linked above is what you need as others have said.
Posted : 29/11/2011 9:57 pm
No wonder ive been getting so confused! so its bb92 then.. ok thanks for your help guys much appreciated!!
Posted : 29/11/2011 10:02 pm
