GX Eagle cable hous...
[Closed] GX Eagle cable housing
2 Users
Just doing a new build for a mate and noticed Sram don’t supply any gear housing with their shifter. What gear housing is everyone using for eagle? Is Shimano ok to use or is there a difference between Sram and Shimanos inner wire? Thanks
Posted : 14/09/2018 8:34 am
SRAM inner is 1.1mm and Shimano is 1.2mm.
In reality, I've always used SRAM inner cable and shifters with Shimano outer and never had a problem, so I wouldn't over think it too much. The other way around would probably be more of a problem as a Shimano inner cable is likely to run a bit sticky in a SRAM outer.
Posted : 14/09/2018 8:46 am
Cheers daern Shimano it is then.
Posted : 14/09/2018 10:34 am
