GX Eagle 1x12 with ...
[Closed] GX Eagle 1x12 with a little slack...
5 Users
Hello, I have a new bike with the new GX Eagle 1x12 and I have disassemble the bolt screw because I like to grease everything after several races. So far so good.
I went to assemble it again and assembly it as I came:
When I have tightened to the maximum torque indicated, there is a small slack in the rear derailleur, is it normal? Add that I can not squeeze more, the next thing would be to break something.
I have seen another SRAM image in which the mounting of that bolt comes like this:
I have it assembled as in the first image. What would be the correct way?
Thanks.
Posted : 06/09/2018 2:36 pm
ive just got a gx eagle mech and its got shift loads of play by hand with out the wheel in and you can hear it creaking - it doesn't translate in reality mind it hasn't hindered shifting, nor any noise
but theres no way my x01 eagle from before had the same amount of play
Posted : 06/09/2018 2:45 pm
Perfect!. Then, is normal in the GX, not?.
And, how have assembly the bolt of the rear derailleur. Like the first image or the second image?.
Thanks.
Posted : 06/09/2018 2:48 pm
There is definitely slack there on the GX Eagle mechs that I have had.
Posted : 06/09/2018 3:41 pm
Perfect, I'm calmer then.
How many nanometers of torque do you put on it? 5 Nm?
Thanks.
Posted : 06/09/2018 3:47 pm
The top pic doesn't look like the GX eagle rear mech, so I'd go with the bottom order.
Posted : 06/09/2018 4:42 pm
Yup, mine came with slop that's got steadily worse over time. After 500 miles it's enough to mean the mech slightly bends inwards as a result. Shifting still seems fine but it's a common problem according to my shop. Will probably try a warranty claim if it gets any worse.
Posted : 06/09/2018 4:57 pm
If it gets worse, I'll do the same...
Posted : 06/09/2018 6:28 pm
