Guide r lever repla...
[Closed] Guide r lever replacement
5 Users
Looking to replace a bent guide r lever mainly because the reach adjust also doesn’t work.
Cheap kits available on Amazon but will it require a bleed after fitting or will it not open the enclosed fluid system during the job?
James
Posted : 06/03/2019 2:53 pm
Yes, looks like you have to remove the hose -
https://www.manualslib.com/manual/1226349/Sram-Guide-Rs.html?page=17
Posted : 06/03/2019 4:05 pm
Arse....
Posted : 06/03/2019 4:16 pm
I've just stripped and rebuilt a pair of guide rs for mate.
It's should be a fairly simple (if a tad fiddly) job to replace just the lever with no need to bleed as you don't touch the internal part of system .
Just take out little rubber plug out-undo small torx grub screw beneath ,push out pin ,remove old lever and then replace with new lever ,install pin.tighten grub install rubber plug and voila your done.
Posted : 06/03/2019 5:13 pm
This - simple to do and no need to do anything with the actual hydraulics
Posted : 06/03/2019 9:55 pm
Excellent thanks, will i be able to replace the lever adjust system as well without affecting the internal part of the system?
Posted : 07/03/2019 1:02 pm
A new Guide R brake is £34 onn Planet X right now, if that's an easier option. A new blade is probably 15-20 quid, new brake will have fresh pads, etc.
Posted : 07/03/2019 1:34 pm
The lever reach adjuster is part of the lever so no need to touch wet side of brakes.
That Planet X deal seems a good option,if you can't source a lever at decent price.
Posted : 07/03/2019 4:49 pm
Cheers did think about replacing the whole unit for one from PX but found a lever kit for 13 quid on amazon
Posted : 07/03/2019 6:37 pm
