GT Fury bearings
[Closed] GT Fury bearings
3 Users
Hi
Does anyone know what type of suspension bearings are used in a 2012 GT Fury?
I'm looking to change mine and have found when changing bearings on other bikes you can get quality bearings for a lot less if you go to non bike specific places.
Posted : 07/08/2013 9:47 pm
Sorry, I can't answer your question, but I like your username!
Posted : 07/08/2013 10:04 pm
No probs mate.
It seemed to be fitting when I got back into biking again a couple of years back. I spent more time upside down seeing blue sky than the trail ahead! Only thing is, now I go much faster but still spend a lot of time inverted!!
Posted : 07/08/2013 10:44 pm
is there a GT Tech info?
If your not using it every day then you could try removing them and getting them matched, I know a lot of LBS that have a stock of "usual" bearings at not silly prices that they can match odd stuff with (normally got from the local bearing shop).
Sometimes manufacturers list them on the spare parts sheet/kits failing that you might have to bite the bullet and be the first to buy a kit and tell everyone else 🙂
Posted : 08/08/2013 12:11 am
