Grumbly gears, chai...
[Closed] Grumbly gears, chain line?
7 Users
Changed my chain,sprockets and bottom bracket.
I now have grumbly gears and no amount of adjusting will sort it.
I'm pretty certain I've got all the BB spacers in the right way .
If they are wrong would it grumble in all gears or just at an extreme?
Posted : 20/10/2021 10:00 am
Whats the chainring like?
I have a rather worn GX 1x11 setup on one bike, that I've decided to use to destruction and I'm collecting 12 speed bits.
I tried a new chain a while back - and the chainring was so horrifically noisy it sounded like something was broken or not meshing. Old chain back on - silent.
Incorrect chainline would, as you say, only causes issues at different points up and down the casette, not all the time.
Posted : 20/10/2021 10:03 am
Or possible incorrect routing of the chain through the derailleur plates.
Posted : 20/10/2021 4:44 pm
A worn chain ring would cause grumbling, especially with a 1x setup when you pop a new chain on.
Posted : 20/10/2021 5:06 pm
Worn chain rings aren't as bad on 2x systems as the chain isn't sat on the same sprockets all the time.
It's an issue I had on my fixed if running chain rings with 'even' number of teeth, and if I'd not changed the wheel/fixed a puncture for ages, and then popper the chain on, one link different, it would grumble. Worn ring. Changing the ring fixed it.
Posted : 20/10/2021 5:08 pm
Narrow-Wide chainring-chain mismatch? Is that a thing on 11sd too?
Posted : 20/10/2021 5:15 pm
IMO chainline isn't really an issue on 1x, not unless it's hideously wrong. And it definitely won't cause issues all the way through the block.
Posted : 20/10/2021 5:43 pm
New chainring ordered. This is making a new drive train a very expensive thing.
Will replacing the chain before it needs doing increase the longevity of the cogged items?
Posted : 20/10/2021 8:31 pm
narrow wide jockey wheels* and the chain on the wrong way (ie half a link wrong) will kind-of function but make a horrible noise.
*no I dont really get why these are needed either.
Posted : 21/10/2021 1:37 pm
New chain ring fitted. No more grumbles.
I've learnt a new thing.
Thanks all
Posted : 24/10/2021 11:46 am
