groupset swap
[Closed] groupset swap
4 Users
I have a new bike on the way and i'd like to remove swap the bars stem shifters & deraillers from my old bike (9speed). & sell the new grouspet (10sp).
I'll be using the new chainset (& rings) so was thinking new cassette/chain required - the other ones will be past saving.
Recabling means new bar tape by the time i add all this up I may as well keep the new kit.
Is there anyway to do it cheaper.
Posted : 05/09/2017 11:01 am
Whats the 10sp worth? Is it worth flogging? New stuff is always nicer
Posted : 05/09/2017 11:04 am
is new tiagra nicer than old dura ace/ ultegra mix. I'm not convinced. It's certianly heavier.
It's probaly worth exactly what i;d spend on 9speed stuff, cables and bar tape.
Posted : 05/09/2017 11:14 am
I'm on the current tiagra, word from in here was it's about the same as the previous 10sp 105 group. No issues with it at all but I'm not really a roadie, pedals go round wheels move and all that
Posted : 05/09/2017 11:17 am
Flog it all and buy new 105/slightly older ultegra. I went from 6700 to 5800 and it's better, gears, brakes and general feel is much improved, lever throw for changing is reduced as well. Might get new 8000 brakes for a bit more power but not fussed about upgrading anything else.
Posted : 05/09/2017 11:35 am
New Tiagra is better than 10 speed 105.
You'll get a half decent amount (couple of hundred at least if you're including brakes and chainset) for the full groupset.
A new 9 speed cassette and chain won't cost much. You deffo need a an old polished silver chainset with your 9 speed stuff.
You'll get cables with the new groupset. Bar tape is easy enough to undo and rewrap if its on a new bike that's not been used. Just done exactly the same myself.
Posted : 05/09/2017 11:57 am
