Grips - ESI - Super...
[Closed] Grips - ESI - Superstar
9 Users
I've seen that ESI grips get a lot of praise, but Superstar have an apparently similar silicone grip for half the price. Has anyone tried them?
Posted : 26/10/2014 9:53 pm
ESI Chunky's are 16 quid, not 30?
Posted : 26/10/2014 10:01 pm
Thought the SS were £6, but was wrong, they're £10. Perhaps not enough of a difference to chance the SS ones?
Posted : 26/10/2014 10:11 pm
I've got ESI racers edge and the SS ones. The SS ones aren't quite as 'sticky' and feel a little bit harder. They are softening up a touch after a few weeks and I'm happy with the grip now and they will hopefully be a bit harder wearing than the ESI's.
Posted : 26/10/2014 10:18 pm
Which do you find more comfortable?
Posted : 26/10/2014 10:23 pm
ESI's maybe just edge it for comfort because of the softer material. The Superstar ones are still comfy though. Not much in it
Posted : 26/10/2014 10:34 pm
Ok ta
Posted : 26/10/2014 10:38 pm
Had both, esi better than ss IMO, ss seem to mould/compress to your hand shape after around 20-30 mins and loose any cushioning effect. Esi stay comfy.
Posted : 27/10/2014 2:04 am
Halfords had clarks foam grips for £4.00 , not tried them but at that price its worth a punt .
Posted : 27/10/2014 7:02 am
Foam grips are much harder than ESIs, and plenty around that price. Foam are also very slippery when wet. I like the ESIs, they are fragile though.
Posted : 27/10/2014 7:11 am
Bought some esi extra chunky grips, they're ok but still not the holy grail for me, solved some of the arm pump and cramping issues I was having on long descents.
They're pretty boring looking though and the tart in me wishes they were prettier.
Posted : 27/10/2014 7:31 am
They come in loads of colours if that helps...
Posted : 27/10/2014 7:33 am
Food for thought then. What about the Ergon GA or GE grips? I'm looking for something that will help reduce hand discomfort.
Posted : 27/10/2014 11:57 am
I think if changing grips hasn't made a noticable difference, then the problem's probably just elsewhere- grips can help but if the problem's in hand position or lever setup or something then it's not likely to fix it... For me it's always braking that does it- deathgripping or bad lever position.
Posted : 27/10/2014 12:45 pm
Wierdly, I used to find this years ago, but since going back to them (Ritchey) they've been fine, maybe gloves are made out of something different that grips them now.
Lock-on foam grips are rubish though.
Posted : 27/10/2014 1:07 pm
