Im putting a Hope pf bb into a carbon bb shell. There is no aluminium apparent in the shell ( Cube carbon HT).
Do i grease the BB where they sit in the shell?
Thanks
please excuse the random use of bold typeface
Carbon assembly paste
Its the Hope 'screw together' PF bb if it makes any difference. Looks like i may have to buy some paste....
Yes, carbon paste. You'll thank yourself when you come to get it out next time. I bought a big tube thinking it would last forever, but I find myself using it all over the place and will probably need to buy more soon!
I once had an alloy seatpost seized in a carbon frame that I bought and I don't ever want to have to go through it again...!
I’ve just fitted the same BB into a carbon frame and used White Lightning Crystal grease which was recommended in other threads. Specifically states that it’s carbon friendly. Used the same stuff for the headset.
Wheels Manufacturing press fit BB instructions
<div>Thoroughly clean the bottom bracket shell. Do not install bottom bracket dry. Identify the material</div>
<div>that your frame’s bottom bracket shell is made of. Use the correct compound for your BB shell mate-</div>
<div>rial!</div>
<div>•</div>
<div>Steel or Alloy BB shells - High Quality Grease</div>
<div>•</div>
<div>Carbon BB Shell - Carbon-Safe Grease (Check with your frame manufacturer for specific brand.)</div>
<div>•</div>
<div>Titanium BB Shell - Anti-Seize Compound for titanium bicycles</div>
<div>I would use White Lightening Crystal.</div>
<div>I would not use a carbon assembly paste like Fibre Grip with bits in it</div>
Used White Lighting Crystal when fitting Hope PF46 and PF41 into recent Yeti carbon builds.
Was recommended by the LBS who supplied frames.
YT told me to use a carbon friendly grease on my pf BB that sits directly into a carbon shell like yours.
I used some Parktool grease certified or some such rubbish for carbon , PL1 or something.
Cervelo also advise synthetic grease, loctite 641 if the fit is loose.
I used a thin smear of suspension grease on the alu/carbon contact point and silkolene rg2 on the rest of it.
The suspension grease was because it's safe on plastic parts.
