Gravity Dropper Mod...
[Closed] Gravity Dropper Modifications
7 Users
I bought a 4" dropper off STW. It appears that it does not have an intermediate position. Has anyone drilled extra holes for intermediate positions? A Google search seems to suggest that it has been done before.
Posted : 24/02/2016 8:57 pm
I think (although I might be wrong) that the multi position inner shaft is solid, whereas the two position (up/down) version is tubular. If that's the case then drilling an extra hole might compromise the strength too much.
You could just buy a multi position inner, of course.
Posted : 24/02/2016 9:51 pm
I drilled extra holes in a t-mars which is the same design. Been ok so far. Just check for cracks when greasing it.
Posted : 24/02/2016 9:53 pm
Presumably that has a solid inner?
Posted : 24/02/2016 9:55 pm
If you're going to drill an extra hole then try and end up with as good a finish as possible and de-burr well when you've finished, to minimise stress risers. Unless you're drilling it on something like a vertical mill then I'd get to finished size in two or three stages, the final stage only taking out 0.020", ideally with a drill with less clearance.
Posted : 25/02/2016 7:57 am
 qtip
Or just save yourself the bother. I've never used the intermediate position on my GD. Partly because it's not particularly straightforward getting in that position, but mainly because I don't see the need for any position other than all the way up or all the way down.
Posted : 25/02/2016 8:17 am
I think 3 positions is great. All the way up for climbs and road, 30mm drop for general riding, all the way down for tech bits. The mid position that some have is a bit pointless though.
Posted : 25/02/2016 8:23 am
Just buy a new inner tube direct from GD.
They don't cost much. You could even convert it to a 5" drop doing it that way.
Posted : 25/02/2016 8:25 am
I find the 1" drop intermediate position useful... run that most of the time and use fully up for lengthy climbing. I would also suggest getting the 5" pre-drilled inner.
Posted : 25/02/2016 10:43 am
Not this.
This. fully up for climbing, 1" down for techy/rolling stuff, fully down for gnar.
Posted : 25/02/2016 10:48 am
