Gravel wheelset und...
[Closed] Gravel wheelset under £400?
11 Users
Looking for a set of 700cc wheels to use on and off road, QR and Sram Xd with a preference for Lightweight over bomproof.
Hope 20Five? Hunt? Justridingalong? Superstar? Something else? Any bargains to be had?
Posted : 22/05/2017 10:12 pm
Hunt 4 Seasons good for the money - as long as your forks don't foul on the 15mm std lock ring... (you need a slim Lock Ring if you have a Genesis Datum 🙂 but Hunt will send one if needed....)
Posted : 22/05/2017 10:24 pm
If your frame is disc can take 40c plus tyres go for a set with 25mm rims. Sometimes XC 29er wheel sets are better on gravel/monstercross/adventure bikes and comparable in weight to one's not marketed at MTBers.
Posted : 22/05/2017 10:50 pm
You can get a set from Superstar, Stans Crest on Switch ultralight (inc road freehub so possible to use road 11 spd cassettes), double butted spokes. Less than £400.
Posted : 23/05/2017 5:00 am
Sorry I forgot to say - disc hubs!
The frame will easily take 42 or bigger so I may well look at lightweight (xc) 29'er wheelsets..
Posted : 23/05/2017 5:19 am
Issue I found is that MTB rims will not handle the high pressures for road tyres.
Posted : 23/05/2017 5:22 am
Hand-built wheels using Stans Grail rims?
Pick the hubs and spokes that you fancy/can afford.
Or, a factory built Stans Grail wheelset. Just seen them on sale for not much more than £350.
Posted : 23/05/2017 5:30 am
https://www.bike-discount.de/en/buy/dt-swiss-r-23-spline-disc-ta-11s-shimano-wheelset-502783
You'll need to add the XD driver.
I've just brought a set, I like them.
Posted : 23/05/2017 6:25 am
 Pyro
I like my Hunt 4Seasons, very good for the money.
Posted : 23/05/2017 10:39 am
Stans Grail on Novatech 771/772 with CX ray spokes cost me about £370 from Spokesman. Recommended.
Posted : 23/05/2017 10:43 am
I have Hope 20Five (normal spokes not straight pull), given them some welly down gravel tracks and the like under my 100kg bulk and they are still perfect.
Posted : 23/05/2017 11:14 am
I went for the handbuilt Hope 29er wheels from Merlin. Mine are built up with Mavic 319 rims but there are a few choices. I went for this option as I needed a 9mm RWS skewer for my Escapade. I'm guessing they're more bombproof over lightweight though... 🙂
If you go for the same rims expect some swearing if you're fitting WTB Nano 40c tyres...
Posted : 23/05/2017 1:03 pm
