GPS Newbie Question
[Closed] GPS Newbie Question
5 Users
I'm thinking about getting a Garmin or suchlike as I mainly cycle alone and would like to start exploring new trails. I have seen data for these trails on sites such as trailbadger.
Can you just download the data to a Garmin and then use it more or less as a sat nav to guide you around unfamiliar trails?
Posted : 04/06/2011 2:24 pm
Yes, some GPS routes are a list of waypoints & the GPS will guide you with direction & distance from one waypoint to the next, but more modern ones will show you where you are in relation to your route that is a line on the map of the GPS.
Posted : 04/06/2011 2:44 pm
most of these files will be GPX files and are very easy to download to your device.
if you have never used a GPS before I think its prudent to mention that they are no substitute to map and compass if you are going riding in the hills where visibility can make navigation hard!
Posted : 04/06/2011 2:58 pm
yes you can use them to navigate but you are often doing it without a map
IME you need both with you but a GPS will help with decisions and stop you getting the map out all the time.
Posted : 04/06/2011 3:21 pm
If you have an iPhone have a look at Trails (can pre download the area maps so you dont need a connection) or Endomondo (can hookup to a heart rate monitor) and has an excellent site for sharing and making challenges. Oh, get a heavy duty case also!
Posted : 04/06/2011 3:42 pm
