Gopro settings ques...
[Closed] Gopro settings question.
6 Users
Evening, my videos look "choppy" once on youtube, especially at speed, i.e. bike moving past a static camera, is that called ghosting or shadowing? and where there are light changes. How do I get it looking better? I use a Gopro Hero 2, record at 720p 60fps and use Sony Vegas to edit and render to youtube as per their suggested settings. Here's one of my video's just to show you what I mean. Thanks.
Posted : 25/03/2016 9:21 pm
Try a different editing suite. I had a similar problem whilst using Moviemaker. The GoPro SW worked for me.
D.
Posted : 25/03/2016 9:29 pm
Vegas is fine, you do not need new software. Are you sure you are rendering at 60fps? Go into the properties and render settings each and check they are both at 60fps (of 59.whatever). Otherwise go on youtube and watch some videos for "best render settings for Vegas 13" or similar to make sure yours is set up correctly. There's some conflicting information out there so absorb much information.
Posted : 25/03/2016 10:50 pm
Thanks. I'll look into it.
Posted : 25/03/2016 11:56 pm
You should tilt the camera further up when its on the chest cam - its pretty distracting seeing your legs in so much of the frame.
Posted : 26/03/2016 12:11 am
Will do rudedog, cheers.
Posted : 26/03/2016 6:54 am
Youtube muddies up the vids. Try hosting them on a different site, like Vimeo
Posted : 26/03/2016 7:26 am
I didnt think youtube shows 60fps, try exporting it at 30fps then uploading.
Posted : 26/03/2016 11:51 am
Tried to upload to Vimeo before and it didn't work. I was obviously doing something wrong! Will try again though. Cheers.
Posted : 26/03/2016 12:36 pm
