I have a GoPro with a Chesty mount but I seem to have an issue with getting it to point in the right direction. As you can see in my first full edit, [url=
It seems to piont at the top tube and the ground as soon as I get out of the saddle. I already have it angled as far up as I can.
Has anybody else experienced this problem in the past and know a good and easy fix??
As you can see the Seat post mount works well but I want to be able to vary my camera angle to try and make the videos more interesting.
Do you mount it upside down? If not change it to 'upside down' mode and mount it upside down, this gives a better range of angles.
There is a straight extension which works very well with the chesty. Usually sold with the helmet front mount. I kind of e-bullied them into giving me one but they can be bought 😉
Other options... Mounting the camera high up on my chest gets it more on the slope of my ribs, that works for me. I think the standard response is to mount it upside down but I change camera mounts a lot and that's kind of irritating.
Fantastic suggestion 🙂 Such a simple idea and now I am thinking to myself "why the hell did I not think of this!!" 🙂
I will give that a go next time i use it.
Thanks!
Northwind, that extra mount looks perfect but i think I will try the upside down idea first as it is cheap (free) and see how I get on. Always nice to have a backup idea though 🙂
This.
I find that you need an angle of around 45 degrees between the chest plate and the camera itself. Should be easy enough to achieve without any extra attachments.
No need to change it to upside down mode on the camera, just flip it using go pro studio
Presumably in-between reboots, blue screens and general 'no device connected' weirdness?
Other video flipping methods exist 😉
Live essentials movie maker is surprisingly good. The latest version of the gopro software is much better than cineform ever was, admittedly. But it still seems to get upset with either the wifi back or the camera if they're ever connected together.
+1 for upside down. If you just watch and dont make edits VLC easily allows you to rotate 180° for easy viewing
Before the "upside down mode" I've mounted the chestie on top of my rucksack's cheststrap - seemed to do the trick 😉
Anyone else noticed the BPM sound of their pump, most likely on ascents while watching the video?
I stuck a bit of old helmet padding to the back of the mount at the bottom which was enough to push the angle out and get a decent angle... £0.00 = 😀
if you are getting blue screen then it isn't anything to do with go pro software. I think it's a great package for free, have the occasional crash but just takes a few secs to reload the rpoject.
