Goodridge hose upgr...
[Closed] Goodridge hose upgrade on hope mono minis - help
6 Users
I want to swap my old hope mono mini hoses for spangly braided Goodridge hose.
The goodridge kit is 35 quid an end. which is a bit pricey.
But the hose is 8 quid a metre.
So can I buy the hose and a few new hope olives and reuse the Hope fittings on the goodridge hose?
cheers
Posted : 04/02/2015 5:58 pm
No
Posted : 04/02/2015 6:30 pm
Different hose outside diameter and bore size - so no.
Posted : 04/02/2015 6:32 pm
http://www.ebay.co.uk/itm/Hope-Braided-stainless-steel-Hose-Buy-Per-Meter-/331406413694?pt=LH_DefaultDomain_3&hash=item4d295c8f7e
Your Hope fittings will transfer over (unless you have the [i]really[/i] old 6mm hose).
Here's [url= https://steveukmtb.wordpress.com/hope-braided-hydraulic-brake-hose-assembly/ ]a guide[/url] I did for the job.
Posted : 04/02/2015 6:52 pm
Yep, exactly the same hose, just a different way of connecting them. Possibly worth noting that the very first 5mm hose fittings that Hope used had a smaller bore for standard hose than those used for braided (one had a hex, one had 2 flats), later standardised as large bore on all types.
Posted : 04/02/2015 6:58 pm
Er. Bought my hope brakes on 2004. And the hose is original.
Posted : 04/02/2015 7:45 pm
If superstar do a kit, you could do a lot worse than that- braided hoses, the bolts etc aren't the lightest but they're perfectly good.
Posted : 04/02/2015 7:48 pm
Have a pic of the fittings?
Posted : 04/02/2015 7:56 pm
