Goodridge hose prob...
[Closed] Goodridge hose problem
6 Users
Bought some of that £7.99 carbon look hose of crc but I can't get the olive over the hose.
Tried trimming the outer cable but this didn't work.
Do I need to buy different fittings or should I just get replacement Shimano hose?
Advice appreciated
Posted : 01/01/2013 9:22 pm
Are you trying to use the shimano fittings or the proper Goodridge ones
Posted : 01/01/2013 9:38 pm
Goodridge hose needs their own fittings. Goodridge hose has a greater diameter than Shimano hose.
Posted : 01/01/2013 9:42 pm
I bought new shimano olives and inserts.
Do you have to buy the whole fitting kit at £20 plus?
Is it worth upgrading to this hose over standard shimano hose
Posted : 01/01/2013 10:03 pm
Yes
No
Posted : 01/01/2013 10:11 pm
I do have Goodridge on several bikes and the only differnace I notice is the colour
Posted : 01/01/2013 10:30 pm
When you trim the outer the braid has a tendency to flare a little.
I was able to widen the olive enough (and tighten the braid a little) to squeeze it on without pulling back any braid
If you can spare a few mm perhaps try a new cut to remove the flared braid and wrap some tape around the outside to prevent it flaring when you cut
Posted : 01/01/2013 10:36 pm
As said above you CANNOT use the standard Shimano fittings ,you will need to buy the Goodridge ones,if they have not changed recently then the ends normally comprise a spike which is inserted into the end of the hose which then has a tight fitting sleeve which screws onto and over this and the hose making a seal,this sceond piece has the banjos for fitting to your levers or caliper.
Posted : 02/01/2013 9:37 am
