Hi chaps,
I need to get a pretty thin m8 washer, are there any good online stores that have a good selection of washers? I've had a look about, and can only really get m8 washers in a 1mm thickness, I was something thinner...
Ricks
Form B washers (which are usually the thinnest "standard" washer) are 1mm thick in M8 size . . . anything thinner will be "non standard" so might be hard to get hold of. Try looking for shim washers instead.
Google Pro-bolt. I've used them in the past 🙂
Search for crinkle washers on ebay, these tend to be thinner @ 0.5mm, they do up flat I use them as shims when normal washers are too thick.
Swirling them on a peice of emery cloth would have them down to size in no time.
