Going tubeless, usi...
[Closed] Going tubeless, using Stans tape.. ok or no?????
7 Users
So,
The clowns in my local bike shop ordered me the wrong size Stans tubeless kit, (the all mountain one instead of the XC one)...
So my options are, either stick with tubes, or try running tubeless using the tape, which I found another shop has the right size of.
I have a 24 hour race over the weekend and was hoping to have it all sorted by now, didn't need this hassle!
Anyone's thoughts on my best option please???
Thanks.
Posted : 16/07/2012 9:55 pm
If you have Stans rims then you shouldn't need rim strips only the tape.
If the tape's too wide, simply apply it and then trim the excess that rides into the bead with a craft knife.
Posted : 16/07/2012 10:10 pm
They're DT rims. Still good to go?
Posted : 16/07/2012 10:13 pm
Order some next day off the 'net.
Posted : 16/07/2012 10:16 pm
I have already put some on order but they won't arrive on time for my race.
Posted : 16/07/2012 10:25 pm
I would personally not be getting into setting up and testing a new tubeless setup this close to a big event, especially without tubeless rims. It can be done but I wouldn't want to depend on it. I'm assuming from your post it's new ground for you though, so if that's not the case feel free to ignore!
Posted : 16/07/2012 10:30 pm
Ive run Stans tubeless system a few times before, mostly with Stans rims though. I had hoped to have my current bike set up tubeless long ago, but things got in the way.
Yes I agree, usually I hate making changes on my bike this close to a race, its one of the big no no's in my book. If it works out though it will be much better than tubes! I usually carry a spare tube, and pump even when running tubeless, to be safe.
Posted : 16/07/2012 10:41 pm
DTs should be fine with tape. Just do it.
If it seals great, if not, tubes it is. I use insulating tape with my wTB rims and it's fine.
Posted : 17/07/2012 6:12 am
Really?
Sounds like a plan then. How do you get the valve to seal properly? Do your tyres ever burp?
Posted : 17/07/2012 6:23 am
Just like you do with a stans rim!
Posted : 17/07/2012 6:49 am
I'm with Northwind on this, last thing you want are any teething issues right now. Think it through and sort it straight after.
Posted : 17/07/2012 7:47 am
been running stans tape on dt rims for 3 years now works fine (though i do have a compressor 😉 ).
Posted : 17/07/2012 7:49 am
