Going to do a bit o...
[Closed] Going to do a bit of road stuff - is a hybrid frame OK?
4 Users
Looks like I'm going to be doing a bit of road riding this year (with MTB buddies who already do a bit of road). There's def no racing involved (usual rides maybe 30 miles) but I think there is a plan to do one 100 mile ride in the summer.
I'm on a tight budget and was wondering if I could also be looking at used hybrids (with drops fitted instead of flats) as well as racers? How different would a hybrid frame be?
Posted : 26/01/2011 11:38 am
Will work fine but having to add drops is expensive. Plenty cheap road bikes on ebay no?
The main difference is gearing and light, narrow tyres - you'd be OK with a hardtail and spare wheels.
Posted : 26/01/2011 11:40 am
I suspect you would find that hybrids tend to have a slightly more upright geometry (so less aerodynamic) and slightly heavier frames. This won't be a problem on most rides, but will slow you down a bit on a 100 mile ride I would imagine. If you discover that you have to spend money on new bars/stem etc, you might be better just buying a road bike in the first place.
There are some "fast hybrids" which blur the lines a bit though.
Posted : 26/01/2011 11:41 am
Re the fitting of drops, I do have an option of a pretty good bike already fitted with drops so no expense there.
Posted : 26/01/2011 12:26 pm
Aero position will matter according to speed, not distance, cumlative effect will of course be greater on longer rides.
SB sounds like a good option if it's a hybrid then you may find the jumps between gears quite big, but you'll be able to fit a closer ratio cassette and narrower tyres if you get that into it.
Posted : 26/01/2011 12:33 pm
Carrera usually have a quick hybrid in their line up. The used to do a Gryphon, which literally was a flat bared road bike.
Putting drops on flat bar bikes is an expensive upgrade also. The top tube is shorter on a true roadie.
Posted : 27/01/2011 8:06 am
