...gear?
Being a retrogrouch I built up my El Mariachi as a 9 speed with a 34T biggest cassette sprocket. When I've been bike packing I've felt my lowest gear even with a triple is still too tall for my ageing legs.
If I went to ten speed with a 36t biggest sprocket, how much lower would my lowest gear feel by comparison. I'm happy spinning small gears, but I never seem to get on top of the 34 and wonder if the investment ton10 speed would be worthwhile for an extra couple of teeth.
Why not just stay 9 spd and fit an expander sprocket? There are a few 38t ones around. Not tried it but might work. Would obviously have to lose a sprocket somewhere else.
You could fit a 12-36 9speed casette that would give you the 36 tooth low gear but you would lose the 11 sprocket at the other end . I think I saw somewhere that Suntour make an 11-36 9 speed casette which would give you the same high and low ratios without the expense of changing to a 10 speed set up .
There's a Deore 9-sp 12-36T cassette. Given you have a triple, I'm sure you'll not miss the 11t ring.
(PS - it weighs around the same as an anchor)
Could also use those ^ 12:36 and replace the 12t with 11t from your current cassette (provided it isn't too worn).
Oh - and if I was changing away from 9-speed, I'd go straight to 11.
There's a Deore 12-36T?!? If I'd known that I wouldn't have gone 1x10 myself!
Anyway, I went 32T/11-34T to 32T 11-40T with an expander and it's great for everything. Oval chainring too, makes a huge difference.
There's also an Alivio 12-36 that you could pick up for less than £15 in places. No idea on weight etc but might be worth a punt?
Alivio 11-34 & 12-36 from CRC at a tenner each, swap the 11t around to give you an 11-36, flog the other cassette for a fiver on eBay, job done. Works grand for me, slightly clunky drop down to the 11T cause of the ratio jump but otherwise great
FWIW it weighs almost exactly the same as the 11 speed XT 11-40 everyone's excited about, and less than the 11-42.
I had no idea there was a nine speed 36t cassette. I don't think I've ever used the 11t sprocket so I wouldn't miss it.
I'll do a bit of googling, thanks for the tip.
Have a play, and compare ratios...
http://sheldonbrown.com/gears/
Going to 10 speed from 9, often the benefit is in dropping to 2x instead of 3x but still keeping largely the same available ratios with less redundant overlap. Though a downside in my opinion of a bigger jump between chainrings and shifting hassle that goes with it.
