Going 1x11 from 2x1...
[Closed] Going 1x11 from 2x11
3 Users
I have stuck a narrow wide chain ring on the 2x11 cranks but the chainline now out of line. Its grinding a bit on the lower gears. Pressfit BB, what can be done to align the chain better?
Posted : 11/02/2016 7:43 pm
1mm chainring washers between the chainring and the tabs to move the ring inwards. Might need longer bolts if more than 1mm needed, but it'll work fine.
Posted : 11/02/2016 7:48 pm
Didn't realise chainring washers were a thing! I'll give it a go, Ta
Posted : 11/02/2016 8:21 pm
Check your bb, my pf has a 3mm spacer on the driveside that can be moved across, but it blends in and is hard to notice.
Posted : 11/02/2016 8:35 pm
I think I do have a spacer but its held in by the BB?
Posted : 11/02/2016 9:27 pm
Yeah, BB comes out pretty easily with a hammer 😉
Posted : 11/02/2016 10:06 pm
lol. just get the chainring spacers... whilst i am sure the above is a bit tongue in cheek, pressfit BB's are fickle at best, hammering them out to refit later is only ever going to result in a rubbish fit and even earlier failure.
Posted : 12/02/2016 8:34 am
