Going 1x10 kids bik...
[Closed] Going 1x10 kids bike
6 Users
bought a 13 bike for wee do and it’s got a triple on it with 10 speed cassette
i have some double cranksets but would prefer single on the front
cheapest way of doing it?
Posted : 16/03/2018 12:37 am
 geex
Cheapest?
FREE - Remove shifter, cable and front derraileur. Remove All the chainrings and bolts. hacksaw the outer chainring bolts (& nuts) shorter. refit the middle ring. - This won't retain the chain all that well.
£5 - Cheapest to do it properly. As above but replace the middle ring with a narrow wide (There are cheap but decent narrow wide rings on aliexpress for around a fiver).
*I assumed you already have a clutch style rear mech on the bike. If not. For the second option. you might want to add in the cheapest compatible one. But this is not essential. Especially for a kids bike.
My XC bike has a non clutch mech but narrow wide ring and never drops a chain. my other bikes see far rougher use and require clutches/top guides to insure no dropped chain.
Posted : 16/03/2018 2:48 am
Fit the double crankset with the small ring removed. Remove the front shifter. Use the front derailleur as a chainguide.
Posted : 16/03/2018 3:37 am
Why????
most kids I know need all the gears they can use......
Posted : 16/03/2018 6:40 am
My lads bike has a triple chainset with the rings removed, and a superstar NW in the middle ring position. I then fitted a bashring in the big ring position, mainly for school trouser chain interface protection but it should also help a bit with chain retention as well.
He's got a non clutch SLX rear mech and has ridden in the alps with out dropping the chain.
I did think of fitting one of those small plastic chain device things that goes where the front mech goes but he doesn't seem to need it.
I think the NW ring does more than the clutch for chain retention...
Posted : 16/03/2018 9:26 am
Exactly what ads678 said.  NW rings are awesomely grippy and can be found really cheap.  No need to replace anything else, just take stuff off.
Posted : 16/03/2018 9:50 am
