Going 10 speed
[Closed] Going 10 speed
3 Users
If I went 1x 10, is there any reason why my 9 speed rear mech wouldn't work in the new set up as it's movement is controlled by the shifter?
Posted : 03/03/2014 7:48 pm
Doesn't work, the cable pull is different so (for mtb parts) there's no direct compatability unfortunately. You can run a 9-speed Shimano rear mtb mech with 10-speed Shimano road front, though, so I guess you could get a flatbar road shifter? But that gets silly.
There's another way to do it- you could, if you've got SRAM shifters, go 1x9 with a 10-speed rear Shimano mech and a wee spacer to tweak the cable ratio, to get the clutch. But takes away the good 11-36 cassette options so it's not ideal.
Posted : 03/03/2014 7:50 pm
 cp
For the same reason that you can't mix shimano and sram kit (except with mods as above), you can't mix mtb 9 and 10.
Posted : 03/03/2014 8:11 pm
Ho hum, I'll stick with 2x9 then, stuff 'em
Posted : 03/03/2014 8:13 pm
