I fancied trying one of these as a sort of 'best of both worlds' between a chesty mount and an out-front mount.
I had some good results with the out-front mount, especially on relatively slow twisty singletrack when I was really leaning the bike in and out of corners (something the chesty doesn't seem to capture as well), it looked great on screen. Just wondering if a headset top cap mount would achieve the same effect but incorporating the bars at either side to frame the shot.
I was hoping for one with a bit of rearward extension but the only one I've seen (which is co-incidentally the cheapest) looks a bit agricultural, it doesn't have the captive Go-Pro 'nut' so looks like you'd need a wee spanner every time you wanted to remove or adjust the camera?
https://www.sjscycles.co.uk/accessories/mwave-qrir-top-ahead-cap/
I think I've got one you could have somewhere if you're not in a tearing hurry.
It's just vertical mind (backward shifting it would find my knees very quickly, I think that one you linked should go forward over a - ve angled stem)
Can you not just reverse your out front mount so it points backwards? Some you can position over the stem by doing that.
think I’ve got one you could have somewhere if you’re not in a tearing hurry
Yes please! Will ping you a message 👍
Ha! Good idea, hadn't thought of that 😎 Would preclude using Garmin (out front anyway) but I had already assumed I would be removing it so as not to obscure the shot, can mount it on top tube or something for navigation duties.
