Glueless Patches?
[Closed] Glueless Patches?
16 Users
Puncture on kids bike tyre and no patches in my tool box. Little look on Amazon showed some glueless patches.
Any good? Yay or nay
Posted : 05/05/2021 8:28 pm
Used park tools ones for years til I went tubeless, worked fine.
Posted : 05/05/2021 8:51 pm
Lezyne ones are pretty good. I put 5 on one tube at once & none failed.
Posted : 05/05/2021 8:54 pm
I've struggled with them. Bought some unbranded ones years ago and they worked great. Have since tried different ones, mostly Park and had around 50% success rate. I think preparing the tube becomes more important, make sure its clean and you'll have a decent chance of success, but they're not as foolproof as a traditional patch and won't provide a permenant fix like they do. They are very useful when you don't want to sit around for 30 minutes waiting for glue to dry though.
Posted : 05/05/2021 9:11 pm
Park, Lezyne and Topeak seem to work well. Not tried other brands.
Posted : 05/05/2021 9:39 pm
Park work for me.
Seem to be permanent. Never actually had to remove one to replace with a tip top vulcanised patch.
Posted : 05/05/2021 10:10 pm
Park ones are fine, just make sure you keep them in a sealed packet and don't let them get wet. Also make sure the tube is bone dry.
The only time they failed on me was when I didn't sand down the raised rubber line on the centre of the tube well enough and it lifted.
Posted : 05/05/2021 10:13 pm
Good when they’re new. But if they’ve sat in your camelback/frame bag for a while, not so effective in my experience…
Posted : 05/05/2021 10:15 pm
Used to use leaches back in the day and have lenznes and muck off ones in my kit.
Posted : 05/05/2021 11:09 pm
Tried a few most work ok but as above need tube prep.
The best I've found is Skabs. I mended a puncture a month ago using one of these, and I'm still riding it now.
Posted : 06/05/2021 12:23 am
Yeah I used to use Leeches too. They were great.
The last Lezyne ones I used were not as sticky as I'd have liked them to be.
Which reminds me... I need to get some tubeless gunk and some valves. And a new track pump.
Posted : 06/05/2021 3:10 am
How old is aforementioned kid?
Learning to fix a puncture is a valuable rite of passage. 😊👍
Posted : 06/05/2021 3:45 am
I found they worked better on a camelbak bladder than on inner tubes. Got to be best part of 15 years that's been on there.
Posted : 06/05/2021 7:38 am
Not had great success. Tended to have been in camelback for years before actually being needed though and had lost their stickiness.
Posted : 06/05/2021 10:35 am
I have used the Park Tool ones for years and they are fine.
I buy from my LBS though, not Besos.
Posted : 06/05/2021 10:57 am
I found the park tool ones work well if you properly prepare the area with sandpaper first and apply pressure afterwards. I had to peel one off earlier today which was over a seam and not quite sealed, and wow it put up a fight. It had only been on there about 24 hours - that glue works better than I thought!
Posted : 06/05/2021 12:09 pm
