Giant Defy sizing f...
[Closed] Giant Defy sizing for 5ft 10 and a smidge
8 Users
Quick question and have searched a fair bit but I am looking at a 2010 Giant Defy in M/L Happy to be stretched out a bit and I have 32 and a bit leg but just want to check if I am along the right line size wise. I know I can go to some shops and ride them but this is my first road bike so its all a bit of an unknown.
Any thoughts?
Posted : 19/09/2019 4:58 pm
Medium and 110-115mm stem.
PS I have a Defy, a Defy SL, two Propels, and am precisely the same size as you (179 cm 32" inside leg). I'm also a BC Coach that fits cyclists. M/L will be too long, you'll need a shorter stem and bike will handle poorly. If you test in a shop, test a Medium but ask them to swap the stem to 110 mm (default is a 100).
Posted : 19/09/2019 5:06 pm
I had a M/L, 5'11" with 32" leg and it fitted great.
The difference in ETT length is the M/L is 56cm and the M is 54.5 - 1.5cm
Wouldn't the M/L with a 100mm stem be the same length as a M with 115?
Posted : 19/09/2019 5:33 pm
I am 5ft 8in and medium fitted me fine, I reckon you need to try for size TBH.
Posted : 19/09/2019 5:50 pm
5'10 and a bit here. I had a 2013 Defy in a M/L and it was too long. And I've only got a 30" leg.
Posted : 19/09/2019 6:14 pm
5'11 32 leg here and I get on with my Defy M/L 100mm Stem ok.   However my good bike is a 54, 24cm shorter TT but 110mm Stem and I feel "faster" on it, yet equally as comfortable.   The HT is 20cm lower so that probably extends the reach of the good bike a little.
Posted : 19/09/2019 7:42 pm
Reach to bars will be the same. Weight over front wheel will not be. A smaller frame and longer stem places more weight over the front wheel and will handle better, all else being equal.
If between sizes, always go smaller.
Posted : 19/09/2019 7:47 pm
It's longer and lower geometry than a Defy but I'm 5ft 10 and rode a M/L TCR. However, to me the M/L Defy looks to have a stupidly tall head tube. Probably easier to sort the reach on a medium than get lower than the tall head tube would allow on a M/L. (Well unless you fit a negative rise stem)
Posted : 19/09/2019 7:48 pm
At 5'10" I bought a M/L Defy as my first bike. Ended up running a -6 110mm stem with all the spacers taken out and still was too high. Few years on am running a 52 CAAD12 with 15mm of spacers and -6 110mm stem.
Posted : 19/09/2019 8:55 pm
How many of you had a Defy not as your first road bike, and still went M/L? 😉
It’s a great bike and a very popular first road bike. I’ve raced mine a few times and it is set up with identical contact positions to my Propels. It’s almost slammed now, but I’ve become a little more flexible. Stem has gone up to 120 mm, and 110 on the Propels. Not hugely stretched nor silly low at the front. Just a perfect fit for long days on the drops
Posted : 19/09/2019 9:03 pm
