Giant Anthem - rear...
[Closed] Giant Anthem - rear suss top out clunk ?
5 Users
Just noticed, on my fairly new Anthem SX, a slight clunk when I pick up the bike around seat tube. All linkages are torqued correctly etc and bike is only a few months old, so no real wear. I can only assume it's a tiny top out movement in the shock ? Not noticeable when weighted or riding etc. It's not saddle or seat post, definitely in the suspension.
Normal or something not right ?
Posted : 12/07/2015 2:11 pm
That's usually the eyelet bushings in the shock that have worn.
Posted : 12/07/2015 2:15 pm
Aye, but its only had about 10hrs riding since new...
Posted : 12/07/2015 3:21 pm
That happened to me on an intense tracer, no idea why. I've owned and race my current Anthem for a year and there's no movement anywhere. Sometime you are lucky, so,etimes you aren't. Change it and see if issue goes away, it's a job that'll be done quicker than you can drink the accompanying cup of tea.
Posted : 12/07/2015 3:36 pm
Thanks, will change it over. Any links to bushings, or LBS for them ?
Posted : 12/07/2015 3:42 pm
Infact will ask LBS to swop them or supply as its only actually 8 rides old.
Posted : 12/07/2015 3:50 pm
I had a wheel dish issue and got LBS to check frame alignment a few weeks ago. It was 1.5mm out, which is 'within tolerance'. Wonder if this would have an impact on bushing wear ? Still odd that it's gone in under 20 hrs of riding from new. Hopefully just a bad bushing from new ....
Posted : 12/07/2015 8:04 pm
It's a cheap fix Iain. If it goes again, warranty the frame with Giant due to the tolerances.
The only other thing I think of is that there's some stiction in the shock and it's not returning. Unusual that though as there's over 100psi forcing it back up.
Posted : 12/07/2015 8:42 pm
Thanks, good point, will drop it at LBS tomorrow and let them see and sort. That way easier if ends up being a bigger issue. Cheers for the advice.
Posted : 12/07/2015 8:56 pm
You're certain the shock mounting bolts are tight? No way the shock bushing goes in 8 rides under any normal circumstances.
Posted : 12/07/2015 9:04 pm
Yes, checked all the bolts with torque wrench..
Posted : 12/07/2015 9:05 pm
Good week in Lamlash mate? Where were you staying?.
Posted : 12/07/2015 9:11 pm
Not normal though is it, it's bent.
Posted : 12/07/2015 9:23 pm
Nobeer - aye, in the Cordon end of Lamlash, mixed weather but got a lot of rides in. When you there ?
Posted : 12/07/2015 9:25 pm
Yes, I am a bit suspicious that it's due to the swingarm being a bit out..
Posted : 12/07/2015 9:28 pm
Heading there next Saturday, same area, oakwood - about 2nd or 3rd last house. Canny wait, Lamlash is so relaxing, is the pier head tavern back open yet?.
A week of food and beer in the drift inn with a daily splash of crabbing off of the pier is a joy.
Nobeer - we were in Glendale, just at the fire station end. PHT seems to still have builders in. Good food in Drift Inn, Coast in Whiting Bay and particularly Fiddlers in Brodick. The club routes up the back of Kings Cross were riding well..
Posted : 12/07/2015 9:37 pm
Good stuff mate, fiddlers pizza is a joy. Rumours were that the PHT was getting turned into flats, good to see that's not happening. Wetsuit ready for the pier!. 😀
Posted : 12/07/2015 9:41 pm
oh well, bike dropped of at LBS, Giant Dealer, who supplied it.....
Posted : 13/07/2015 10:31 am
Update us Iain, I hope its something simple and works out for you.
Posted : 13/07/2015 10:42 am
Kryton57 - Member
the tolerance which has already been confirmed as in spec?
If it's the swingarm that's slightly out that then shock wont be seeing any extra loading. If the pivot points on the front end are out then it might as the load through the shock could be uneven.
Did you check to see if there is play at the top eyelet?
Posted : 13/07/2015 10:47 am
legend - thanks, useful points. I wasn't able to work out where the play was coming from, but I did check that all the pivots were properly torqued, which they were... by elimination it could be a linkage, or a shock pivot. Cheers
Posted : 13/07/2015 10:52 am
