Ghost shifting xt c...
[Closed] Ghost shifting xt clutch mech issues!
6 Users
Afternoon stw, I'm running an xt clutch rear mech ( medium cage), with a 11-34 xt cassette, xtr chain, and 34 race face nw chainring on my orange blood. I'm getting a lot of ghost shifting when pedalling out of rough sections or corners.
Any one else had this problem, and know a solution? Or any ideas how to fix it?
Posted : 28/04/2014 12:34 pm
Frame flex?
Worn bearings on main pivots allowing the rear triangle to waggle about?
Posted : 28/04/2014 12:56 pm
Checked your chain for bad links or do you have any hub play?
Posted : 28/04/2014 1:02 pm
Thanks for the replies, Not checked the frame for flex, ill have a look at bearings tonight.
Hub has recently been serviced, so that should hopefully be still ok.
Posted : 28/04/2014 1:06 pm
Has Rear Mech taken a knock?
A bent mech hanger can cause shifting issues however much you fine tune the barrel adjusters
how worn is the chain?
Posted : 28/04/2014 1:28 pm
Outer cable too short?
Posted : 28/04/2014 1:46 pm
All the gear is only four months old, so shouldn't be wear problem.
The mech did get a knock second ride in, but its not bent and still shifts fine. Just seems to ghost shift when the back end is compressed, so I'm thinking cable or worn bearing.
Posted : 28/04/2014 2:12 pm
Ok so checked all the above, and can't see any issues with any of them. Would chain length make any difference to ghost shifting?
Posted : 28/04/2014 6:22 pm
Cable outer too short then.
Posted : 28/04/2014 6:33 pm
Or chain growth if the chain too short.
Posted : 28/04/2014 6:38 pm
Thanks for all the replies, longer outer cable has been put on.
I'll get out tomorrow night for a spin and see if it helps. If not I'll try a couple more links in the chain.
Posted : 28/04/2014 8:21 pm
