Ghetto Huck Norris?
[Closed] Ghetto Huck Norris?
12 Users
Evening folks, just been looking at the Huck Norris rim defender tyre interface thingys and wondering what people's thoughts are on using this as a "ghetto" solution...
https://shop.deltarubber.co.uk/rubber-strip/expanded-neoprene-rubber-strip/expanded-neoprene-rubber-strip.html
The strips are available in 50mm which is the same width as the HN I'd need for ny set up. I figure that all I'd need to do is notch the edges so it grips the tyre, and cut a few holes through the middle to let the sealant flow through.
If this strip will work it'll do two wheels for a quater the cost of the HC
Sooo yay, nay or maybe?
Mark
Posted : 08/09/2017 9:06 pm
I'd have thought that'd be way to soft. EPDM is used for air seals and its pretty compressible. I think the Huck Norris foam is more like a Plastazote
Posted : 08/09/2017 9:14 pm
I don't get this whole huck norris type system
I'm 200lbs, ran some ridiculously low pressures (<18psi) and never had any issues.
In 6 years of tubeless Ive had 2 punctures that wouldn't seal and and that was because the tyre was destroyed. The covers racing and alps stupidity.
It feels like a solution to a problem that doesn't really exist or warrant it
Posted : 08/09/2017 9:19 pm
They also do a rubber version which might be tougher but a tad heavier...
https://shop.deltarubber.co.uk/rubber-strip/solid-neoprene-rubber-strip/solid-neoprene-rubber-strip.html
Slightly more expensive as well but still a fraction of the price of the HN
It not really the puncture protection that I'm interested in - it's more for protecting the rim. Or am I completely missing the point
Posted : 08/09/2017 9:23 pm
Again, 200lbs, hit every single rock and root with zero dings. You'd have to be an absolute putz to destroy a rim
Posted : 08/09/2017 9:54 pm
Well you're either a riding god or a massive mincer 🙂
I weigh a lot less than you, and over a decades worth of tubeless I've probably trashed about half a dozen rims and at least twice as many tyres, punctures occasional and pressures in the 20-35psi area depending on size/use. Same again if not more in the preceding non-tubeless decade before that...
About 50/50 split in terms of racing or training when breakages happen so not always when I'm tired or being silly.
Fair play to you if you never puncture or ding rims but some of us mortals do, and until we've learnt to be super smooth at full speed we might still need the extra pressure or protection until we've mastered it 😉
Not a HN user BTW but I can see why people are using them.
Posted : 08/09/2017 10:11 pm
 mboy
My sides are literally splitting!
I'm 30lb lighter than you, run WAY more pressure in my tyres, and I've done plenty of damage to rims over the years from "just riding along"...
Ok so we're not all the same, I'm not trying to challenge you to a pissing contest either, my point is there's ALWAYS someone out there that rides harder than you and breaks a lot more kit, no matter what you think...
Huck Norris works cos it's closed cell foam. Put some open cell in there, and not only will it absorb pints of sealant like a sponge, but it will do sweet FA towards actually protecting your rims!
If you MUST ghetto a Huck Norris, buy a closed cell foam camping mat then cut it into strips.
Posted : 08/09/2017 10:13 pm
Thanks for the input chaps, found a couple of places that do the Plastazote in strip form so I might go down that route.... or just suck it up and get the HN 😀
FYI - I'm 75kg fully tooled up and I've spazzed quite a few rims in my time even with 25psi + tyre pressure. Just think its a good idea for that bit more security
Cheers,
Mark
Posted : 09/09/2017 12:24 pm
Im a Putz
Posted : 09/09/2017 12:30 pm
You don't get much Putz these days.
Posted : 09/09/2017 1:05 pm
The whole "I never cracked a rim" is the same bullshit as the "I've never had a problem sealing tubeless tyres" crowd. No, you aren't special. No, these other people aren't being retards.
In this case you probably just ride slower than them.
Also it's about cornering stability, tyre roll and burping air. Again, if this has never been an issue for you at <18psi and 200lbs you just aren't cornering that fast.
Posted : 09/09/2017 2:21 pm
 mboy
Bravo sir, well said! 😉
Posted : 09/09/2017 6:07 pm
Huck Norris using Putz here. Only on the rear in the DH bike but it's great. Recently saw that the rocky mountain EWS riders use arch rims and huck Norris.
Posted : 09/09/2017 6:15 pm
130lb Huck Norris Klutz here, loving them for riding the Lakes. All my tires get killed by tearing at the bead when they get pinched against the rim. Happens with SuperGravity Scwalbes and TCS Tough WTBs. This system means I can run tyres that aren't dual ply monsters. Afer getting through 12 tires in a year previously, the HNs have quickly paid for themselves.
Posted : 09/09/2017 8:20 pm
I thought they were using cushcore?
Posted : 09/09/2017 9:46 pm
Yes your correct - they're using cushcore with Stan's arch rims
Posted : 09/09/2017 10:19 pm
My humble humble apologies
Posted : 10/09/2017 7:03 am
In my ongoing quest for a DIY Huck Norris I stumbled across these.... https://www.csixx.co.za/products/foamo
You can get 4 shipped to UK for less than £80! Seems like a great alternative to the HC with a more realistic price tag
Cheers,
Mark
Posted : 11/09/2017 12:45 pm
nickjb
As Nick says it would be Plastazote, a polyethylene to be more precise. Polyethylene is a closed cell foam so will not soak up any of the sealant.
You can buy a sheet for around £8 [url= http://www.ebay.co.uk/itm/CLOSED-CELL-POLYETHYLENE-FOAM-WATERPROOF-INSULATING-FOAM-SHEET-1MM-12MM-BLACK-/253101059212?var=&hash=item3aedffac8c:m:mt3nT960dP41_TlTwvCSNxQ ]plastazote[/url]
Let us know how you get on. 😉
Posted : 11/09/2017 4:05 pm
