Getting tyres on a ...
[Closed] Getting tyres on a Crest rim
8 Users
 Gunz
I've just invested in a new Crest rim for the rear. As I'm riding an old frame I have to get quite narrow tyres as the clearance is minimal. The problem is that the Kenda Nevegal 1.9 I have is almost impossible to fit without pinching the tube.
Am I missing something, is there a special method to it?
Posted : 24/09/2013 10:44 am
 bol
Make sure the bead goes right into the well of the rim at the top and sides while you pull it on at the bottom.
Posted : 24/09/2013 10:56 am
 IA
Don't use a tube.
Posted : 24/09/2013 11:00 am
 Gunz
Bol, do you mean I should push the tyre into the centre of the rim whilst getting it on?
Posted : 24/09/2013 11:07 am
Sorry to answer the question for you Bol, but yes push the tyre into the centre of the rim.
I did not want to go tubeless just yet and also had problems fitting the tyre on the 29er crest rim, use neet washing up liquid on the bead of the tyre and push the inner tube up into the tyre out of the way...Althought you should not need to use tools (if it were tubeless) I did find that I had to use a plastic tyre lever to get the last bit on.
[url= http://singletrackmag.com/forum/topic/i-feel-like-such-a-kb-cant-fit-a-tyre ]null[/url]
Posted : 24/09/2013 11:41 am
Out on the trails ?
Posted : 24/09/2013 11:49 am
 Gunz
Many thanks Cyclebiker (good link), I'll get working tonight.
Posted : 24/09/2013 11:53 am
I think you have to wait for the planets to align or something.
Posted : 24/09/2013 11:57 am
In the centre of your Crest rim is the 'drop channel' - you need to get the bead right into the middle of this to give you enough slack to get the final part of the bead over the rim.
And start opposite the valve... you won't be able to get the bead into the drop-channel where the valve sits, so this should be the very last section you fit.
Posted : 24/09/2013 12:23 pm
But run them tubeless... it's actually easier than running them with tubes, though you need to know how if you have a flat that won't seal!
Posted : 24/09/2013 12:25 pm
 IA
Though tubeless you'll have yellow tape in rather than a rim strip - a little thinner and a little easier to get the tyre on.
Posted : 24/09/2013 12:27 pm
 dc11
When trying to get the last bit on, I found tying the tyre tight to the rim at a couple of points helped.
Posted : 24/09/2013 12:47 pm
 Gunz
IT'S ON, IT'S ON.
Thanks you all for the 'push the tyre into the centre' tip, wasn't that hard after all and I'm now no longer terrified of punctures.
Posted : 25/09/2013 3:10 pm
