Not that technically minded so bear with me.
Just bought this replacement [url= http://www.chainreactioncycles.com/fsa-orbit-1-5-zs-headset-no-57-/rp-prod80063 ]headset[/url] which is semi integrated.
The one that came off seemed a lot less integrated especially given the fact there were about 2 ball bearings left.
Do i need to apply grease to this or is it already greased up inside?
Thanks for helping a numpty. 😀
More won't hurt...
[url= http://www.bikepro.com/products/lubricants/lube_jpg/u_goose_grease.jp g" target="_blank">http://www.bikepro.com/products/lubricants/lube_jpg/u_goose_grease.jp g"/> [/img][/url]
(personally, I'd lift the seals and grease it up but many won't)
*Gaggles*
Oh, no, sorry. I meant giggles.
oooof !
got away with it by the skein of your teeth, Flash
I'm going to have to think of some more goose related puns. Let me fire up Google and have a gander.
OP, just go and have a look in your gavage - I'm sure any grease will do
Oh, are me and my mates no good then?
[img] https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTs1ZLEh8r2AI0VWUWIYxdnoK7E0voet7dLZLmlfbwxUCJWdwbn [/img]
Cheers fellas. Followed reply nr 1 - more cant do any harm.
Got it back together now - took me a while to realise that i didnt need all of the bits that came in the package (the alloy cups to be precise). Initially it felt a lot better and i was pleased with myself as i really am pretty pathetic with practical stuff. However when i bounced it down the steps on its back wheel, I could feel a bit of a jarring in the frame as i held it. I think i will take it apart again and just make sure its all seated as tight as possible. Not now though as the beer is open!
Thanks again WW
Any chance we could have a gander at it mate to check grease level
I'm here all week
Edit dam you flash just read your gander comment
I'm here all week
You should have been here about 45 minutes ago....
lightning
Sounds like the headset isn't quite tight enough, undo the bolts on the fork/stem and tighten the top bolt a quarter turn, then do the stem bolts up again...
Cheers DB that is sorted now - before 8am on a Saturday! Go me!
You'd be qwakers not to try that.
NB - your "gease" are hanging in the National Gallery 🙂
Have you put the new cartridge bearings (parts 5 & 8) into the old cups that were in the frame? From what you said above it sounds like the old headset had loose ball bearings so the cups could be different.
[img]
[/img]
Have you put the new cartridge bearings (parts 5 & into the old cups that were in the frame? From what you said above it sounds like the old headset had loose ball bearings so the cups could be different.
I have replaced the old headset with a new one of the same model. However thinking about it, if the old cups were still on the frame then that would explain some of my confusion last night.
Everything 'feels' right. I think....
